Question about Bialetti Mukka Express
Muka express bialetti leaking
Hi there!! Hope you can help me... I just fell in love with bialetti coffee makers. I have 2 and I just bought the Muka express... for my discontent, whenever I do coffee or capuccino, it leaks a lot on the side.. how can I solve that? Thanks a lot!!
Posted by janaina_soar on
Frostbite
    New Friend:
  • 87 Answers
Easy!! Not making coffee or cappuccino, go to Starbucks less issues LOL
Posted on Apr 14, 2015
4 Related Answers
Anonymous
SOURCE: Cleaning problems
Hi - I just clean mine with hot water (no soap), and dry it with a towel then leave it on the window sill... My problem is that the coffee can taste a bit metallic at times; and i want to know if I should be cleaning it after every time I use it... Suggestions?
Posted on Jun 23, 2008
ginko
Ginko
  • 19396 Answers
SOURCE: coffee has started becoming weak
Basing on personal experience (you can find more on Google probably), solutions are:
On percolated (filter) coffee machines:
Check water temp, if water temp is insufficient , most common is scale heating element , faulty element, faulty thermostat.
Check if water is dripping right at the center of the filter, if it is dripping on one side because the orifice is clogged, that can result in weak coffee.
Coffee blend not well distributed on filter basket.
On Espresso machines:
Check water temp, same as filter coffee machines (thermostat element, scale on heating chamber).
Ensure that coffee is filled correctly in the filter cup (fill at level), and well pressed.
Ensure that the coffee mixture that you are using is not too coarse, buy the apposite one for espresso.
Ensure that you are not leaving the machine brewing for a time that is too long, and Italian coffee cup is very small, approximately one regular shot.
On the hob moka pots (espresso, Moka and Bialetti type):
This are the trickiest ones, you need art and practice to get a good espresso with a Moka, but when you learn, the result is better than what you may get with an home electrical espresso maker.
The frame on the hob must be not too strong, and the mixture coarse but well pressed, with water at level tag, or you will get a weak coffee.
On Mokas a good strategy is keeping hob at minimum, and turning up the flame at top when coffee starts coming out.
French and turkish cafetieres:
Ensure that you put enough coffee, water hot enough, and that you left the infusion enough time to get a strong coffee.
Note: insufficient pressure and clogged lines on electric machines never give you a weak coffee, exactly the opposite.
Not pressed mixture always gives weak coffee, but too much pressed mixture may give you coffee with bad taste.
Posted on May 22, 2009
Anonymous
  • 7 Answers
SOURCE: How much coffee?
Fill it as full as you can with fine ground coffee. I cut the resulting brew with an equal amount of boiling water. Called an "Americano" in Italy.
Posted on Jul 17, 2009
Avi
  • 66 Answers
SOURCE: Need a copy of instruction manual for Bialetti
hey, screw the 2 parts tight and before that check if the filter plate is not clogged. See this guide that I wrote Avi
Posted on May 21, 2011
2answers
Hi, I bought a Bialetti mini express maker in Italy, but it does not seem to be working. The lights are on and the water pump makes a loud noise, but no water comes out. Can you please help? Thanks!
Did you two buy the machine in europe and travelled back to the USA? If so, the machine can't be used there. You will need a 230V power plug in the house before it can do anything. Otherwise you have to buy a power converter from 115 to 230 V.
Hope this helps
Bialetti Coffee maker repair
Sure it can. http://www.bialetti.com/coffee/stovetop/moka-express/spare-parts-c-1_7_22_32.html or http://www.amazon.com/s/?ie=UTF8&keywords=bialetti+spare+parts&tag=googhydr-20&index=aps&hvadid=32661633397&hvpos=1t1&hvexid=&hvnetw=g&hvrand=3217975301600862448&hvpone=&hvptwo=&hvqmt=b&hvdev=c&ref=pd_sl_53u2x7ta30_b
2answers
How much coffee?
8helpful
Handle of Bialetti Moka Express 10 cup...
There is a tiny pin at the top where the handle slides into a slot between 2 aluminum walls. That pin needs to be "punched" out. I used a nail and hammer, but a tiny nail punch might be safer if you have one.
Cleaning problems
Bialetti Mukka Express Logo
Top Bialetti Coffee Makers & Espresso Machines Experts
Pierre Laplante
Kolbrun...
Ross Keen
Are you a Bialetti Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
