SOURCE: 2001 Saturn SL2 shifting hard jerks...sometimes
This could be a dirty filter. i would start there and replace fluids with lucas tranny fluid. Does it change when the car warms up i wonder ?
SOURCE: rover 75 v6 starts no problem runs 1000 rpm then
check idle speed sensor on your intake manifold around 700 to 750 rpm is normal ,air temp may efect idle speed .
SOURCE: my 2002 Hyundai Accent goes into 1 gear smoothly,
CHECK ENGINE light??? Whenever the 'CHECK ENGINE' (Service Engine Soon) light comes on, the ECU (Engine Control Unit) sets a Diagnostic Trouble Code (DTC). These codes identify the particular engine management system which caused the light to come on.
You'll need to use/find an OBDII (On-Board Diagnostic) Scanner to retrieve any code which have been stored in the ECU computer. Afterward, we might be able to help you DIAGNOSE the problem and perhaps eventually fix the problem.
SOURCE: Renault Megane Scenic 1.6 petrol jerking in 1st & 2nd.
check hoses for splits...i had the same problem.
SOURCE: TRANSMISSION 2nd to 3rd GEAR HARDSHIFT
