Question about Apple Audio Players & Recorders
How do I delete songs from my ipod? - Apple Audio Players & Recorders
Posted by Stacy Gross on
Michael Lei
    Master:
  • Apple Master
  • 498 Answers
The common way is deleting song one by one within Music app on iPod. However, if you want to delete songs in batch, here recommend Leawo iTransfer. You can follow the below steps to complete this task.
Download and install Leawo iTransfer on your computer. The below guide shows you how to delete music files from iTunes with iTransfer in detail.
Step 1: Connect your iPhone to computer
Connect your iPhone to computer and then launch Leawo iTransfer. It will detect your iPhone instantly.
Step 2: Choose music to delete on iPhone for iTunes
Open your iPhone's Library and then go to Music tab to choose the songs you want to delete from iTunes. Just tick the ones you don't want.
Step 3: Delete songs
On the upper side, you could see a "Delete" option, by clicking which you could then freely delete songs you don't want. Confirm the music deletion by clicking "Yes" on the pop-up "Delete Media" interface.
After deleting songs from iPhone, you could then sync your songs to iTunes. If you have logged in iTunes with the Apple ID you have logged on your iPhone, the result will by synced easily.
For more details, check: How to Delete Music from iTunes
Posted on Sep 16, 2019
Brian Sullivan
  • Apple Master
  • 27,725 Answers
There are two ways to delete music from your iPod. The first is to delete songs in your iTunes library and have iTunes sync your library to your iPod automatically when you plug your iPod into the computer. The second is to manually delete music by resetting the options to a manual setting and deleting music directly from your iPod without affecting the songs in your iTunes library. Follow these steps to delete music from your iPod. Open up iTunes by double clicking on the "iTunes" icon. Go to "Library" on the far left side of the screen. Click "Music" from this list, which will bring up all your music on the main part of the screen. Choose a song you would like to delete from the list and right click on it. Click "Delete" from the drop-down menu that appears to delete your song. Go to the bottom of the left column on the screen to "Playlists." Click on one of your playlists to bring up the list of songs in the list. From there you can delete a song on the list. Connect your iPod to your computer. The iTunes program will automatically sync your iPod to whatever you have changed in your iTunes library as long as it is set to the default settings. Manually Delete Music Connect your iPod to your computer. Open up iTunes. Choose the third option in the "Options" menu called "Manually manage music" by checking the box next to it. It will ask you if you are sure you want to manually manage music on your iPod. Click "OK." Go to "Devices" on the far left column on your screen. You will see your iPod's name directly underneath that with an arrow pointing to the right. Click on the arrow, which will cause it to rotate until it is pointing downward and a drop-down menu will appear with all your songs listed. Click on a category or playlist, which will bring up all the songs in the list in the main section of the screen. Choose on a song listed that you would like to delete and right click on it, then click "Delete" from the drop-down menu that appears to delete your song.
Posted on Apr 10, 2013
5 Related Answers
Anonymous
SOURCE: can i put new songs onto my ipod without the other ones deleting?
EACH TIME YOU HOOK UP TH EIPOD IT REINSTALLS ALL THE EXISTING SONGS ALONG WITH NEW ONES. YOU CANNOT DELETE THEM AFTER YOU INSTALL THEM OR THEY WILL ALL BE DELETED THE NEXT TIME YOU HOOK IT UP.
Posted on Jul 27, 2007
Anonymous
SOURCE: IPOD Shuffle deletes songs if I delete them from the music library in Itunes
You have to keep all the songs that you want on your iPod on your computer, otherwise you will get this problem. So if you want song "a" on your iPod it must also be in your iTunes library at all times unless you don't want it on your iPod anymore
Posted on Oct 03, 2008
Anonymous
  • 68 Answers
SOURCE: Songs I've put on Ipod aren't there.
You need to sync it
Posted on May 09, 2009
jamielwright
JAMIE L.WRIGHT
  • 75 Answers
SOURCE: all my songs deleted from my ipod
Try the link.It may help.
http://www.recovermyipod.com/
Posted on May 31, 2009
hunter19_46m
Curtis Sewell
  • 7482 Answers
SOURCE: How do you delete a song from an Ipod nano?
Deleting Files,Pictures,etc from MP3 Player
Hook up your mp3 player to your computer Go to your desktop and double left click on "My Computer" When it opens you will see listing that says "Devices with Removal Storage" your mp3 player should be listed there. Right click on your mp3 player, and a window will open, right click on "Open" and now your files/songs should be visible. Hold the left click down and drag it across all the files/songs that you do not want this will highlight the files/songs you do not want, release, right click and then click on "Delete" Now you mp3 player should be clear of the files/songs you do not want. Be careful and do not delete files needed to operate your MP3 player. Good Luck, I hope this helps Please rate me, Thank You
Posted on Dec 13, 2009
How do i delete all songs on ipod shuffle and then reload? I want to empty it and start over as if new
Generally speaking, people will clean up their iPod with iTunes to erase the old songs and add new songs. iPod users have two ways to delete music from iPod with iTunes, and they can be helpful when iPod users want to get rid of the unwanted songs. iTunes provides automatic and manual methods to help iPod users manage the songs in their devices. When you are using the automatic way to manage iPod music, every time you connect iPod to computer with USB cable, your iPod will sync with iTunes Music library. If you have your iTunes Music library organized, you can delete unwanted music from iPod with this easy method. If you want to manually edit your iPod music, you can check Prevent iPods, iPhones and iPads from syncing automatically in iTunes by clicking Edit > Preferences > Devices. Then you can manually sync the songs and playlists to your iPod with iTunes.
http://www.leawo.org/tutorial/how-to-delete-music-from-ipod.html
Feb 08, 2017 | Apple iPod Audio Players & Recorders
I bought an ipod 2gig nano with 117 songs downloaded. I like maybe 30. how can I delete the other songs?
Step 1: To Delete the songs you don't like from iTunes library: Launch iTunes > Click Music mark > Select My Music > List your music as Songs > Select the songs you don't like > Click Delete to remove them. Step 2: Connect your iPod to computer > Sync the music from your computer to iPod with iTunes
Sep 07, 2016 | Apple iPod nano
How to delete songs from an ipod shuffle
You can uncheck the songs on iTunes library first, and then sync iPod with iTunes, the songs will be deleted from your iPod. Or you may try this iTunes alternative, it's easy to delete your iPod songs, videos and photos.
http://www.reviewstown.com/itunes-alternative.html
Hope it helps. Feel free to email me if you need further help.
Jan 30, 2014 | Apple iPod shuffle Second Gen. Silver (1...
How do i delete songs of my i pod
The first way is uncheck the songs you want to delete on iTunes and then sync iTunes with ipod again, then the songs you want to delete will lose from iPod.
The second way is use leawo iTransfer to delete songs from iPod, the way is connect iPod to leawo iTransfer, then right click on the music you want to delete from iPod on leawo iTransfer to choose "Delete", then the music will be deleted soon. However, this tool can only work on Windows computer.
Jul 30, 2012 | Apple iPod touch
How do i delete all my songs on my ipod?
Hi inthebag pik...
Try this easy way to delete your unwanted songs...
Deleting Files,Pictures,Videos,Audio Books, Apps,etc. from MP3 Player/Ipod
BIG WARNING: DO NOT DELETE THE FILES NEEDED TO OPERATE YOUR MP3 PLAYER.
Hold the left click down and drag it across all the files/songs that you do not want this will highlight the files/songs you do not want, release,right click and then click on "Delete"
ONE MORE BIG WARNING: BE CAREFUL AND DO NOT DELETE THE FILES NEEDED TO OPERATE YOUR MP3 PLAYER.
Please take time to rate me thumbs up
Sep 17, 2011 | Apple iPod nano 5th Generation
How do you delete songs from Ipod?
To delete music connect ipod to itunes on computer.In music folder under your ipod name you can then delete music.
Apr 30, 2010 | Apple iPod touch
How to delete songs from ipod nano
Sync the Ipod with computer , go to Itunes, and delete songs from there.
If you want to delete songs manually you have to set the Ipod to manual sync , follow instructions here:remove songs from iPod without iTunes
Oct 24, 2009 | Apple iPod nano
How do you delete songs from your Apple iPod 4 GB Silver?
You can set your iTunes to "manually manage music and video", then plug in your iPod to iTunes, and delete the songs from your iPod with iTunes.
Or you may try this ipod tool, it can help you delete iPod music easily, Much better than iTunes
http://www.ipod-transfer-copy.com/ipod-iphone-to-computer-transfer-cucusoft.html
Hope it helps.
Sep 07, 2009 | Apple iPod nano
Songs deleted, but empty space and song info. still remain
Get yourself anapod from Redchair software, this works on older PC's and you just drag and drop songs onto your ipod.Its also very easy to delete tracks aswell.Anapod supports adding and deleting photos onto the ipod.
Apr 03, 2008 | Apple iPod nano
How do i download songs on to my sony atracad mp3
How to manually manage content on your iPod-
Get your iPod.
Connect it to your computer.
Start iTunes program.
In the source list, select your iPod.
Now click on iPod options.(On the bottom right corner of iTunes) and select Manually manage songs and playlists option.
Click ok and done!
So here' s how you remove songs form your iPod manually.
  • Connect your iPod to your computer.
  • Go to the source list and click on the icon which looks like an iPod.
  • Choose the songs you want to delete and press delete! How simple is that?!
How to remove songs from your iPod automatically. (When you iPod is set to default settings)
  • To remove songs from your iPod automatically, just delete the songs you want to from your iTunes library.
  • When the default setting is on, songs that are deleted from your iTunes Library will also be deleted from the iPod.
Mar 23, 2008 | Apple iPod MA446LL/A MP3 Player
218 people viewed this question
Top Apple Audio Players & Recorders Experts
ThaMp3Doctor
ThaMp3Doctor
Muntejaya Ginting
Muntejaya Ginting
Geoff
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
