SOURCE: fault code 01
this is actually a fault code error code 1 not one minute check your manual as codes different on some machines from memory i think 1 is a filling fault this machine uses fuzzy logic if water fill takes longer than 4 mins (low pressure) machine stops can be restarted by pressing start button.
see if machine will complete just a rinse cycle.
good luck
SOURCE: Bosch WFE 2021 machine does not complete wash...
Hello i have just had the same problem, i followed the manufacturers instructions (drained and cleaned pump etc) but the washer would not empty and fault 3 spining and rinsing would show. i tried to run the pump on cycle 7 with the filter cover open and the pump was not running. At the rear of the pump there is a spring/retainer this had dislodged and would not allow the pump to run it took a light push (with the power off) to relocate this spring/clip in its housing. Hope this helps
SOURCE: i have a bosch WFE 2021, the fabic softner will
Remove the drawer from the dispenser housing, get a stiff piece of wire, and form a right angled bend in it about 1" long.
Poke the wire into the holes in the top of the dispenser and wiggle it about to clear the holes.
This should solve the problem.
Please rate my solution.
Thanks.
