Question about Sharp LC60LE810UN 60 in. LCD TV
POWER LIGHT FLASHES ONE SHORT AND ONE LONG FLASH.
What is the problem? THE PROBLEM IS THAT ONE OF THE LED's STRIPS IS BAD!
SHARP AQUOS LC60LE810UN RESET INSTRUCTIONS
1)Plug in TV to electric current First then wait until LED start flashing.
2)Press Volume DOWN [ - ] HOLD BUTTON.
3)Press Channel UP [ ^ ] HOLD BUTTON.
4)Press Power [ (') ] HOLD ALL three buttons until LED stops flashing and then release.
·This will reset the TV in order to fix the problem.
·THE FIX IS TO REPLACE ONE OF THE LED's. You need to open the back of the TV and you will also need to remove the front cover and panel to get to the LEDs. The TV will need to be placed facedown and on the backside. This is a 2 person job to turn the TV on its sides. Be careful with the white computer connectors (wide white strip) at the base of the TV where the TV stand sits. You will need to disconnect this in order to get to the LED's.
Once you have the LED's exposed, you will need to unplug one by one by placing the new strip next to it until the unit turns on. You will have to use the RESET procedure above if the Power lite flashes. The Power lite MUST BE ON SOLID - no blinking in order to test the strips. The LED's will flash, but still one of them will be burned. Even if you stare and all the strip light-up, you will still need to check one-by-one!
Once the TV lights up, your face will also light up with joy! Put everything back together and you are set. If you need the complete instructions which come from Sharp as to how to disassemble the unit, please send me an e-mail to [email protected] Please note I don't check this address daily, so a few days wait may take for you to receive the instructions.
Where can you buy the LED's - try searching Yahoo.com or Google.com for resellers.
SHARP AQUOS LC60LE810UN LCD STRIP INFORMATION
LONG STRIP (49 LED's)
FRONT SIDE
BACK SIDE
RL 94v-0
E329419
1029
LFa
Sn-Ag-Cu
Ps-1
K4458TP
4458ZZ
0921FM
104863
ee03A
SHORT STRIP (30 LED's)
FRONT SIDE
BACK SIDE
RL 94v-0
E329419
1025
LFa
Sn-Ag-Cu
Ps-1
K4459TP
4459ZZ
0714FM
302213
Mm05A
Posted on Dec 11, 2013
SOURCE: No POWER
How many times does the POWER led flash per second? (Dont worry about the OPC).
1x (steady constant blink) = Lamps or inverters
2x = Power Supply
3x = Main Unit
If i am reading it correctly, looks like the POWER led is flashing 2x, which means it is a power supply failure. Either way, your TV needs to have a board replaced, there isn't anything you can do to fix it yourself. Try locating your local sharp authorized service center to repair your TV (1-800-237-4277)
Posted on Mar 16, 2008
SOURCE: sharp Aquos will not power on. OPC flashes green
I had it picked up to be fixed on warranty. Downside is I'm out a TV for a week.
Posted on Nov 23, 2009
SOURCE: MY sharp aquos LC45GX6UTV will not turn on, the
Tries unplug,replug the tv back in like an hour later,the tv now,it resetting itself back to the factory setting.The tv now,should work.If it not,than the tv power supply board is dead.That the board,where the power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Posted on Oct 16, 2010
SOURCE: My sharp aquos lc 37d62u will not power on; the
It is detecting shorted circuits or power supply problem, need in-depth troubleshooting. Inspect the power supply module first for any sign of bad caps with domed tops, DC output voltage readings check.
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Or www.digikey.com, just make sure to use caps with low ESR, 105c, high ripple current and long life rating such as PANASONIC FM or FC series.
Posted on Mar 28, 2011
Testimonial: "Very quick response and very helpful. Thank you!"
SOURCE: Sharp aquos LC-37HV4M,Wont power up,no screen
Power supply bad: part number RDENCA032WJZZ Do a search with the part number on Ebay or www.shopjimmy.com to see price and availablity. Be sure to match numbers off your board to the parts listed. A google search will bring up other suppliers.
Posted on May 28, 2011
Jul 28, 2018 | Sharp Televison & Video
Feb 11, 2015 | Sharp Aquos Televison & Video
Feb 03, 2015 | Sharp LC52LE640U 52 inch 120hz AQUOS LED...
Jul 14, 2014 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
Apr 19, 2014 | Sharp Aquos Televison & Video
Aug 19, 2013 | Sharp Lc60le640u
May 03, 2013 | Televison & Video
Dec 04, 2011 | Sharp LC60LE810UN 60 in. LCD TV
Jul 14, 2008 | Audio Players & Recorders
Mar 13, 2008 | Sharp AQUOS LC-32D43U 32 in. LCD...
Feb 11, 2016 | Sharp LC60LE810UN 60 in. LCD TV
13,339 people viewed this question
