Question about HP G60-535DX 15.6in Laptop PDC 2.1G3GB 500GB DVDRW
Laptop hpg60 black screen and power button remains on
HI. I opened it to clean the cooling fan and fix the left clicker. I used compressed air on the motherboard and after I put it back together. I connected with power charger not the battery, the screen wont turn on completely black and the power button remains on will not switch on/off
Posted by giovanni on
Mazagange
    New Friend:
  • 24 Answers
Dear gorgaman1
Open your lap again and ensure that you connected all parts correctly especially the screen chip.
Best Regards
Mazagange
Posted on Apr 10, 2013
Screen won't turn on/Power stays on
To do a power reset, unplug your laptop, remove the battery and hold the power switch down for 30 seconds.
otherwise it may be problem with your screen back light...
Apr 10, 2013 | HP G60-535 Laptop Notebook Netbook...
Fan not working powers up then off with black screen
OverheatingWhen the CPU overheats then it will shut down (i.e. thermaloverload) and won't boot up again until it has cooled down. If this is theproblem is not fixed then the CPU will eventually fail.
A faulty fan causes the problem or the fan and heat sink assembly are cloggedwith dust.
Check the CPU fan to see if it spins freely, if not replace the fan.
If the fan and heat sink is clogged with dust the remove the dust and make surethe vents are clear and dust free. Use a small brush and can of compressed airto do this.
Jun 09, 2012 | Toshiba Satellite L45-S7423 Notebook
Aspire 5742 i3-370m overheating how do i fix it
Three things that will make a laptop overheat:
1. Dust - Dust inside the laptop, dust clogging the vents, dust around the fans, dust around the cpu and heatsink. To fix it, take the laptop apart, take a can of compressed air and blow out the dust.
2. A fan is not working. To fix it, you will have to take the laptop apart to replace the fan.
3. The Thermal Paste around the cpu and heatsink has dried up or is too thin to keep the unit cool. To fix, take the laptop apart and apply a fresh coat of Thermal Paste.
Another work around for a laptop that is overheating is to by a Laptop Cooling Pad that has fans on it and it plugs into the usb port of the laptop. The laptop sits on it and it keep the laptop cool. You can buy a laptop cooling pad for less than $20 from Tiger Direct.
http://www.tigerdirect.com
When the site opens just type Laptop Cooling Pad in the search box at the top of the screen then press GO. Sort the returned results by Price Low to High.
May 16, 2012 | Acer Computers & Internet
My dell laptop sensor pad is not responding all the time can you help
Buy a can of compressed air, attach straw, slightly lift left clicker with finger nail and give good blast of air in the crevice, "few times" repeat with right clicker, this will clean out any dirt and hopefully fix the problem.
Mar 31, 2012 | Dell Computers & Internet
I hear noise coming from the back vents and I think it might be the processor fan. Is there a way to fix/clean it so that noise goes away and do I have to open it from the bottom? This is for Qosmio G25.
You probably need to replace the cooling fan, but you can try cleaning it out first. Get a can of compressed air or use an air compressor to spray pressurized air into the vent to spray dust out. If this doesn't work, you probably need to replace the fan. I actually found a guide for opening up the Qosmio G25 and replacing or cleaning the cooling fan. Check it out:
http://www.irisvista.com/tech/laptops/toshiba-qosmio-g25/replace-cooling-fans-1.htm
Sep 24, 2011 | Toshiba Qosmio G25-AV513 Notebook
Question about a fujitsu lifebook P5010. when i power up i have a blank/black screen although i can hear the fan running constantly. the little lcd display area next to the power button works. there are...
Hi insurancedud...
Try blowing the dust out of the laptop by using compressed air in a can or an air compressor, the compressor is the pefered choice (max air pressure 90 psi).
Blow the air into the fan discharge of the laptop, (be sure not to overspeed your fan) then blow the air into the intake of the fan.
Do this a few times until you have no more dust in your laptop.
Then see if that cooled it down, if not maybe your fan is faulty and not cooling properly.
You can also put a cooling pad with fans under the laptop to help cool , they have the laptop coolers with usb power.
Please take time to rate me thumbs up
Sep 11, 2011 | Fujitsu Computers & Internet
Hi there is a toolbar coming up the whole time saying,,,,,WARNING a problem with the cooling system has been detected, please turn of the computer and return for service immediately
Try to fix the problem without taking the laptop apart first but I would recommend using a powerful air compressor instead of a vacuum cleaner.
Welcome to FixYa! Based on the error you have received, this means that the cooling fan of your laptop needs to be cleaned and checked at. This is a common problem with any toshiba laptop. I suggest checking the heatsink of your laptop. If the CPU heatsink is not clogged with dust and lint completely, you can use canned air and just blow it inside the laptop through the openings on the bottom and on the sides. It's nice as a precaution measure, but it might not work if your laptop already has a problem and the heatsink is completely clogged.
  1. Open the laptop case, so you can access the CPU fan and the heatsink. In some cases you can access the heatsink through the latch on the bottom of the laptop. Sometimes (for example Toshiba Satellite A70/A75) you have to open the laptop case all the way down.
  2. Carefully disconnect the fan cables on the system board and remove the fan. If the fan makes unusual sound when it spins (grinding sound), I would recommend to replace the fan.
  3. Clean the fan and the heatsink with compressed air.
  4. I would also recommend removing old thermal grease from the CPU and applying new grease for better heat conductivity.
  5. If your laptop is still under warranty, you can take it to any Toshiba Authorize Service Provider and fix the problem at no charge to you.
Hope this helps! Thank you for using FixYa!
Jul 27, 2011 | Toshiba Satellite 1715XCDS Cooling Fan...
My ispiron 1318 will log on but just five minutes later it will stop responding. the only solution to this is to shut it off manually.
sounds like an overheating issue. your fan and/or cooling vents may be clogged and need cleaned.
an easy way to try and fix that is using compressed air (you can get cans of compressed air form computer shops) let your laptop cool down before you use compressed air though, as the air comes out very cold it could damage your laptop if its still hot inside.
Hope this helps.
If it does not clear the dust you will have to open up the laptop and manually clean it out from dust.
Jan 03, 2010 | Dell Inspiron 1318 Notebook
Laptop won't boot up
1 suggestion.
Inside your laptop is a processor. The Cooling Fan, and Air Intake Duct you mentioned, are part of the cooling system. The main job for the cooling system, is to keep the processor at a reasonable operating temperature.
When a processor becomes too hot it turns off. (Actually BIOS turns it off)
With the amount of foreign debris you mentioned, (Dust/Dirt/Hair/Carpet Deodorizer/Food Crumbs/Lint, are a few examples of foreign debris), the Cooling Tube may be clogged.
Just using a can of compressed air for computers, in the Air Intake Duct, (DO NOT blow into the Exhaust Duct!), may not be enough.
Generally the Cooling Tube is about the width of your finger, and the height is half the thickness of a finger. Pretty small tube, and easily clogged. Also the Heatsink at the end of the cooling tube, can become clogged.
Laptops have a poor cooling design anyway. Everything is crammed into one tiny box. They use a small fan to cool them, and the Air Intake Duct is typically located on the bottom. (Some are on the side) This is a good (?) area to inhale readily available foreign debris.
On the link below the last photo on the page, shows an average Cooling Tube that is attached to a Heatsink.
http://www.insidemylaptop.com/clean-cooling-module-acer-aspire-3620/
This requires opening the laptop, and physically removing the foreign debris. Typical method is a combination of Q-tips, and Isopropyl Alcohol, plus a can of compressed air.
(AC adapter {Charger} removed, battery removed. Use an ESD wrist strap, and connect it's alligator clip to a good ground)
By the way. You DID have the AC adapter, (Charger), disconnected, and battery out, when you used the can of compressed air, right?
Jul 25, 2009 | Acer Aspire 5720-6661 Notebook PC
HP G60-535DX 15.6in Laptop PDC 2.1G3GB 500GB DVDRW Logo
90 people viewed this question
Top HP Computers & Internet Experts
Lee Hodgson
Lee Hodgson
Ekse
Muntejaya Ginting
Muntejaya Ginting
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
