Panasonic NV-GS11B Mini DV Digital Camcorder Logo
A
Anonymous Posted on Apr 09, 2013
Nv-gs80 driver for mac - Panasonic NV-GS11B Mini DV Digital Camcorder
1 Related Answer
LvLinux R
  • 73 Answers
  • Posted on Nov 30, 2010
SOURCE: searching for driver for NV-GS80
Do you mean a driver for the webcam portion of the camera, or to transfer footage to your computer from the tape? If you mean for footage transfer, then you are in luck, because no driver is needed. You just need your video editing software and it will communicate with the camera over the firewire port and cable.
If you did mean for the webcam feature then you should be able to download it from the support section of panasonic.com
Where can i buy a data cable for my panasonic pv-gs80 that can config wiht my pc
Ask for IEEE1394 cable also called iLink or firewire.
Beaware that firewire has several types of socket configurations.
In most cases a 4 pin to 6 pin cable will work.
4 pin goes to the camera 6 or 9 pin goes to PC or Mac.
Al
Panasonic nv gs30 can support mac
Connect the camera to a Mac and open iMovie then capture.
You will need a 4 to 6 pin firewire cable.
Note: Some Macs have a nine pin socket and some base models have NO firewire socket.
Searching for driver for NV-GS80 on windows vista platform.
Where can I get panasonic nv-gs11eb drivers for mac?
There are no drivers needed- you need to use the DV output (which is actually just a mini firewire 400 port) the other end of this cable is a full sized 6-pin firwire 400 cab;e that should slot into any mac (pre 2009 when some changed to the bigger firewire 800 ports). You cant use the USB. to capture the video, I use final cut pro athlough I'm sure imovie will let you do it.
4helpful
Mac Driver for Panasonic NV-MX500
I have a NV-MX500 and I need to connect to a PC to play do i need to capture video in windows movies maker
2answers
NV-GS11EB
the best solution is to buy another camera
19helpful
Removing fader on Panasonic NV-GS80 video camera
TURN YOUR CAMERA INTO MOVIE RECORDING MODE. (THE RED VIDEO CAMERA ON THE DISK). tHEN PRESS THE MIDDLE OF THE JOYSTICK INWARDS. THEN MOVE THE JOYSTICK TO THE LEFT ONCE TOWARDS THE ARROW. THEN CLICK THE MIDDLE OF THE JOYSTICK AGAIN. HOPE THAT HELPS.
Top Panasonic Video Cameras Experts
NOEL
NOEL
Are you a Panasonic Video Camera Expert? Answer questions, earn points and help others
