Question about Ultra Linear Audio Players & Recorders
Ultra linear ps 12480 arcing - Ultra Linear Audio Players & Recorders
How do i get a printout of meter read for toshiba 557
Refer to the Counter Tab 6 in the manual. Download from here: http://business.toshiba.com/downloads/KB/f1Ulds/12480/FC-2050C_TAG_EN_0008.pdf
Mar 03, 2015 | Toshiba Office Equipment & Supplies
Tip
Prone to arc eyes from welding?
If you have a conventional flip lens welding helmet and are prone to getting arc eyes from "peeping" though a gap to strike your arc, try this.<br /> Replace the inside fixed clear lens in your helmet with a yellow perspex lens. The world will appear strange at first through the yellow lens, but the yellow cuts out the ultra violet rays that cause arc eyes. The yellow lens should not be considered a replacement for the dark glass, it is only to shield you from that inadvertant flash when making your strike.
on Jan 19, 2011 | Welding Tools
I have a 2003 ultra.....when it's not running
There will always be a small arc from the computer, clock, etc. If it's a big spark it will most likely be the starter solenoid. Check your battery cables for a bare spot and make sure all the lights are out. Try pulling one of the smaller wires off the starter if you can and see if it helps , or just change the starter.
Sep 25, 2013 | Cars & Trucks
Ultra Linear UL600HC gain pot broken off of board
No, open the system, check the switch in questions, get a soldering iron and desolderer to remove the switch, do it carefully, when you have the switch in your hand go to maplins or somewhere like it, find an exact replacement(wont be hard to do) and get someone confident with a soldering iron to solder it back in.
Aug 31, 2009 | Ultra Linear UL-600HC Car Audio Amplifier
Hobart Ultra Arc 350 3-phase blows breaker in fuse panel
if you have a airgas dealer they carry hobart parts im not sure why you are blowing circut brackers unless they arenot big enough
Aug 17, 2009 | Welding Tools
How to hook up linear ul4400d to my two alpine 10" subs. Running pre amp out of deck . only driving subs
if they ar dual voice coil wiring them ing the box parralle and play your wm in bridge mode
Apr 10, 2009 | Ultra Linear UL-4400D Car Audio Amplifier
Power light on the amp goes on after 5 sec off ultra linear 1200
If you run the remote from the battery you will need a on/off switch. Sounds like the amp is overheating. Also, I don't understand bridge the remote and power. They should be seperate going into the amp.
Dec 23, 2008 | Ultra Linear UL-2200D Car Audio Amplifier
Sony PS-LX500 Linear tracking turntable
I think it's kind of cheap to ask someone to pay $10 for an answer to one question. Sheesh!
I haven't gotten the answer yet, but a local stereo store pointed me in the right direction. Thanks anyway.
Regards,
Tom
Sep 19, 2008 | Sony PS-LX250H Turntable
Wish to purchase a certain model am/fm / cassett in dash player deck single dimension
Well, I finally just broke down, went out and purchased a brand new am/fm/cassette player. These type stereo decks are kind of scarce now -a-days. It was reasonably priced and hope it will last longer than the old Phase Linear PCR4500.
Thanks for sharing and caring.
Best Regards,
ORTH
04/09/08
P.S. The new rig is a completely different name manufacturer.
Apr 09, 2008 | Car Audio & Video
42 people viewed this question
Top Ultra Linear Audio Players & Recorders Experts
Muntejaya Ginting
Muntejaya Ginting
 Grubhead
Grubhead
Are you an Ultra Linear Audio Player and Recorder Expert? Answer questions, earn points and help others
