I Need I Fresh Panel, Sanyo EMO-V6 Microwave Oven Panel My Mail Id [email protected] Mob: 9840341501
Click this link to understand the working
of the microwave: How the microwave works
for spares check on the links available on the site above.
SOURCE: Oven not working
Just click below for more information;
http://www.repairclinic.com/0088_6_1.asp
Hope this may help;
DON'T FORGET TO RATE:
SOURCE: light bulb replacement for sanyo ems3553 microwave oven
If
there's no obvious removable cover over the bulb (most often on the
rear or side) and the owner's
manual doesn't address it, then disassembly will be required.
You'll need to remove the outer cover (wrapper) to get to the bulb.
Always unplug a
microwave before removing or installing any bulbs.
If
it's an over the range type, remove the vent grille across the top and
see if bulbs can be accessed there. There may be a panel on the bottom
covering the light(s), instead.
If not, chances are
you'll have to remove it from the wall, then remove the outer cover. If
so, the installation instructions are very handy, and it's best to have
two people since the microwave can be heavy and awkward.
If you don't have your
instructions, please reply back with your brand and model number.
Once it's out of the
wall, the outer cover (wrapper) will need to be removed, just as you'll
need to do on a counter top model.
On a
counter top model,
be sure it's unplugged, but otherwise ignore the instructions
above this paragraph.
See these links before proceeding:
http://www.microwavedisplay.com/safety.txt
http://www.microwavedisplay.com/disassembly.txt
The
screws you need to remove should be pretty obvious, but a special
driver (such as a T20H type or GTXH20-100) may be needed.
Be sure to put all the
screws back in the right holes, since some may be special grounding
screws.
Bulbs can be had locally in most
grocery stores, hardware stores, home improvement centers, and big box
or department stores.
Many models use halogen
lamps. You must not touch the new one with your bare skin, as the oils
will shorten the bulb life.
We're
happy to help you with free advice and we'd appreciate your thoughtful
rating of our answer.
