Question about KitchenAid Food Mixers
What year wasmy mixer made
Model ksm90pswh Serial wf 5070711
Posted by miller9936 on
MendingShed.com
    Novelist:
    Scholar:
  • KitchenAid Expert
  • 134 Answers
The ksm90 mixer has been being produced for many years, the only way to find out when your mixer was made is to call KitchenAid with the serial number. They should be able to let you know when the mixer was made.
Posted on Apr 12, 2013
My kitchenaid ksm90pswh is making a lot of noise from the back of the unit....cant seem to fix it....any help?
Try looking at the Service Manual:
http://www.kitchenaidparts.eu/documents/pdf/service-manual/classic-svc-manual-new-email-version.pdf
Feb 11, 2015 | KitchenAid Food Mixers
Model type and serial number
It depends on the model I guess, look underneath the pedestal.
Apr 22, 2014 | KitchenAid Food Mixers
How to tell what model i have
Look for the model & serial number underneath the pedestal.
Age of a Hobart Stand Mixer by Serial No.
the ML or spec number would be trackable from the resource site.
Enter the model number and check the date of the corresponding build number.
https://my.hobartcorp.com/resourcecenter/Pages/FilterByModel.aspx
If it does not have a safety cage fitted, there are some areas of the countyr where it can not be used commercially, untill one is fitted. Depending on the model, that would be a thousand dollars or more.
Mar 23, 2014 | Food Mixers
Where do you find the serial number for a 5 quart glas bowl for the Artisan mixer
The serial number for all KitchenAid mixers is located under the base of the mixer. You will need to carefully tilt the mixer over, and underneath the mixer you will find a label with the model number and serial number.
Feb 16, 2013 | Kitchenaid 5 Quart Glass Bowl Artisan...
I have model A-200-D Hobart mixer. Serial # 1575984. It is leaking oil into the bowl. Who can I call to get an estimate to service or repair this machine?
The oil leeking into your bowl is old grease that has broken down into oil and is getting past your oil seal you need to take out all of your old grease and oil replace it with hi-temp grease or a good grade lithium grease and replace your agitor shaft oil seal
May 16, 2010 | Food Mixers
I need a serial number on model ksm158gbca kitchenaid mixer
Not usre i understand the question. The serial number of your item should be on the machine, sometimes on the bottom.
Mar 11, 2010 | KitchenAid Food Mixers
Service manual for hobart mixer s301
Give me the serial number,also hobart does'nt release their service manuals to the general public.However if you goto hobartcorp.com type in your model which is a d300 and you can access an exploded view of the parts.I work for hobart and service these mixers often.Any questions let me know.
Mar 29, 2009 | Food Mixers
Can it be repaired?
hi have a nice day
Have a look at link below for step by step repair procedure of a food mixer.
http://home.howstuffworks.com/how-to-repair-small-appliances4.htm
Does it help?
Feb 21, 2008 | KitchenAid KSM90 Ultra Power Series Stand...
Food Mixers Logo
219 people viewed this question
Top KitchenAid Food Mixers Experts
Appliance engineer
Colin Stickland
Colin Stickland
Lee Hodgson
Lee Hodgson
Are you a KitchenAid Food Mixer Expert? Answer questions, earn points and help others
