Large black cartridge not printing at all.
Hello
Perform a nozzle check, whichever colour is not printing ensure that it is refilled correctly and the cartridge is full of ink (PGBK- Larger black cartridge)
Being edible ink it is far more viscous than the normal dye that is used in these printers. We at rihac have companies that use edible dye in their printers, leaving them for extended periods of time can result in blockages.
The best way to unblock a cartridge is remove the printhead from the printer and sit it on a paper towel with the blue windex sprayed onto the towel, also spray windex into the top of the printhead where the cartridges are seated. Sit the printhead on this for 30 minutes and move it to a new section of paper towel another 3-4 times.
Dry off the printhead as best you can reinstall it and perfor a headclean and you should now be in business.
We see this regularly with people using our inklink products, remember to use your printer regularly to avoid blockages.
SOURCE: Canon MX850 will not print from small Black Ink Cartridge
Canon PIXMA MX850 Multi Function Printer Printer Canon MX850 will not print from... Answer Canon MX850 will not print from small Black Ink Cartridge - 8BK. It only uses the large black ink... (More) Canon MX850 will not print from small Black Ink Cartridge - 8BK. It only uses the large black ink cartridge and I have a drawer full of small 8BK cartridges. How can I get it to use the small black cartridge and not the large black cartridge? Thanks
SOURCE: I have the Cannon Pixma mp620 and I am getting
The small black ink cartridge is the photo black cartridge. If you're not printing any photos that's why it is still full.
SOURCE: PM530 printer: PGBK cartridge not working. Just
Clean the feeder use Que tip With Alcohol only let it dry and clean the cartridge the same way replace the That should solve the problem, Also keep in mind if you are using a cartridge that is a refill The cartridge sometimes dry out Have that checked it might be bad other words plugged up. Good luck with it
SOURCE: Canon Pixma iP2000 wont print black ink?
Canon IP 2000 / reset
1. Turn off printer
2. Hold down Resume button and press Power button.
3. Keep holding down Power button and let Resume button go.
4. Press Resume button 2 times then let BOTH buttons go.
5. Green lights will flash and then stop blinking.
6. When green lights are solid, press the Resume button 4 times.
7. Press the Power button and the printer should turn off, if not,
press the Power button once more.
8. Your printer should respond as normal..
SOURCE: Coloured printer with black not printing?
Breath and Relax... this should resolve your problem.
Routine maintenance and keeping full ink tanks will prevent this problem, however if you have the problem you can resolve it by doing the following:
1. Clean your ip3000 print head using denatured alcohol solvent which can be purchased from most hardware stores. If unavailable, use 91% Alcohol (isopropyl alcohol (first aid antiseptic) which is available for less than a dollar at most Walmart pharmacy departments.
*Warning: You may want to use a pair of latex exam gloves as this is a messy process and can stain your fingers.
Supplies needed:
Isopropyl Alcohol or denatured alcohol
paper towels
latex gloves
sink, bowls and or basin
can of compressed air
very small screw driver
tablespoon or baby bulb type syringe
warm water
Time necessary 45-50 minutes
1. Lift print head from printer. It pulls out easily because it is held in with the same down lever that holds the cartridge in place.
2. Put two layers of paper towels in the bottom of a dish to protect sensitive sprayer heads.
3.Put enough solvent in dish to cover the screens on which the cartridges sit when in use.
4. Take the two small screws out that hold the white ceramic piece
5. Gently, pry the ceramic piece back and away , to reveal the underside (No need to pull away the glued points on the sides.)
6. Gently, move head up and down to slosh solvent around it the best as you can. Use a table spoon or syringe to pour solvent over all orifices in the print head, turning it upside down and then back a few times.
7. Use canned air with a plastic straw to blow into and through all orifices, alternately sloshing/swishing and pouring solvent over head (be careful not to touch any of the holes, screens, or sprayer heads with anything)
8. Empty dirty solvent from bowl and replace with paper towels and clean solvent. Soak for approx 10 minutes. Rinse again with clean solvent poured directly on all parts, letting solvent overrun and fall into dish or basin.
9. Gently shake the solvent off the head, take it outside and spray with compressed air into all orifices to clear out and help evaporate any remaining solvent. Let sit on a clean paper towel for approx 20 minutes. (There may be a little ink bleeding out of the head, but once it dries completely it does not present any problems.
10. Reinstall head, cartridges and it will print like a new printer.
SUGGESTION: For many years of problem free printing, keep a double set of ink cartridges, one set full at all times. Whenever a cartridge runs out of ink, replace it IMMEDIATELY, with a new one or a refilled one. This gives the print head no chance to dry out and create clogged heads. Routine maintenance of cleaning the heads every 24 months does wonders for keeping your ip3000 in new condition.
Happy Printing .
