Our water pipe outside the house (that controls the water for the undergound drip lines) must have froze one night and now sprays water :( how do i fix it??
How can I fix it myself??
Posted by melkur on
  • melkur Apr 09, 2013
    thank you so much for replying... but its not the actual drips lines that are the issue-- its the above ground pipe that are next to the house that leads to the underground drips
Chris Hingee
  • 32,281 Answers
Purchase a plastic joiner that fit the diameter of the drip line.
Cut the drip line where it is leaking and remove the damaged section then join the drip line together with the joiner you have purchased.
Posted on Apr 09, 2013
  • Chris Hingee
    Chris Hingee Apr 11, 2013
    If the damaged pipe is plastic then get a plastic joiner that fits and fit the pipe as I described previously.
Main water turned off. all fausts opened in house. trying to replace an outside hose pipe. can not stop dripping water to sauter new faust.
Hi. Jam two slices of white bread into the pipe to form a dam to stop the water. Solder the pipe. Then turn the water back on to clear the bread from the pipe.
Aug 14, 2011 | Plumbing
My meter has registering over 86,000 gallons of water used over a 2 month period. Plumber has checked inside and outside of house and no leaks. We did the check where you turn off the house water and...
Patti, check outside around the outside water spigots. to see in the earth around and near the spigot(s) is overly wet or moist. Someone may have been turning them ON when you weren't at home or a night, as a practical joke. If so, it was a sick one. Also, have your municipality , who provides the water to check "their meter", as something may terribly wrong with it mechanically. Do not accept "No" as an answer. Did you plumber consider a leaking under ground pipe from the meter to your home? Especially, if it is a galvanized pipe, instead of copper or plastic.
Hope this provides more info to consider. Thanks for choosing FixYa.
Aug 04, 2011 | Heating & Cooling
Water is dripping from the inside unit and not coming out of the drainage pipe outside
The reason the water is coming out of the unit and not the drainage pipe outside is for a few possible reasons.
1 -the drain pipe is clogged / plugged (due to calcium build up,or frozen)
2- the line is kinked or blocked.
check the drain pipe carefully, there may be obstuctions.
Feb 21, 2011 | Heating & Cooling
Hi..we have switched on AC yesterday night after 3months. Water started to drip from the front. What could be the reason and fix to the problem?
Clogged drain condensation drain pipe. They use to recommend white vinegar for cleaning, but they now say even it can damage lines for being to strong. The sell a product Zest at home depot, it's like orange and environmentally safe made with oranges or something.
Anyways use that stuff.
I would first check the outside pipe for an obvious blockage like grass, dirt or dead animal. Then right by your indoor unit will be the start of the same pipe, if the leaking is there, then that's it, if it's somewhere else could be in the unit which you will need a repair man, nothing easy inside the main unit except lots of shocking things.
Open the pipe inside and try pooring some cleaner in , wait a bit then turn back on and see. If it's a bad clog, what I did was to take a long hose, run it in the house to the pipe. I put folds in the hose to do it alone, or have someone outside to yell to turn it on. Put the hose against the pipe inside flush as possible and that should force almost anything out. Be sure to have a couple towels ready cause it's nearly impossible to not spill some water doing it this way.
Sep 12, 2010 | Samsung Heating & Cooling
Outside unit is running but blower in attic is not working line in attic from outside unit is dripping water
You need to get the blower motor going, the unit is froze up. Try switching the fan spped wires on the control board on the unit in the attic.
If that does not work, replace the motor
Jul 03, 2010 | Heating & Cooling
I have a Weather King AC/Furnace in the attic that's dripping water into the drain pan. When we purchased our new house it came with this unit and it never dripped ater. Now, the water is dripping towards...
I assume it is dripping water when the AC is running. If you look at the attic unit, there should be a PVC pipe running from the unit - probably an insulated PVC pipe. This pipe probably goes across the attic to the edge of the house and drains outside. The drain pan may also have a drain pipe, but the one on the AC unit is the issue, and is probably plugged. Go outside and see if you can locate the AC drain pipe. See if the ground is wet below the pipe and if water is steadily dripping from the pipe (with AC running). If the pipe and ground are dry, the pipe is plugged. If you have a wet/dry vac, try connecting it to the drain pipe outside to see if you can **** the pluggage out. If you can get it clear, water should start dripping out of the pipe. This same thing happened at our house. I decided to cut the pipe in the attic, and add in a PVC isolation valve, tee, and water hose connection with plug, so I can valve out the AC unit from the pipe, remove hose connection plug, and hook up a water hose and flush the line to outside. Lowe's sells all of the PVC pipe fittings. The water pressure from the hose will always flush out the algae and crud to the outside of the house. I can also remove the plug and pour a cup of bleach down the drain pipe every couple of months to keep algae growth in check. I also cut out the trap (u-leg) from pipe in the attic and purchased a ready made trap a Lowes (the contractor who built our house had made a lousy homemade trap). I purchased a few PVC elbows and installed the trap on the drain pipe outside. By the way, our AC drain pipe comes out of our wall outside and drains near our outside unit. Our secondary drain pan drain pipe comes out outside from an eave on the side of the house. I don't know what you drain line looks like (it may have a port to add bleach, or some cleanout provisions, maybe not). If you choose to modify/improve it, then make a sketch of it, go to Lowe's and get the PVC parts you need + PVC pipe primer and cement. PVC cement dries fast. Remember, the pipe must flow downhill from you AC attic unit. You can use a regular wood saw to cut the pipe. I hope this helps you. You need to keep the drain line clear as algae will continue to grow in it. Pouring bleach in the line every month or two helps. You also need to check maybe once a month that the line is draining properly (check to see if dripping outside). You can get some serious water damage to your ceilings if the water backs up and overflows. I discovered that our drain line was plugged just in time as our drain pan drain line was also partially plugged and drain pan was about to overflow.
May 08, 2010 | Weather King 12AJA4201AH Air Conditioner
Excessive water dripping from Central A/C drian line
sounds like the overflow drain is picking up the water that means the main drain is clogged.you need to find the main drain pipe if lookin at the air handler in attic there should be 2 drains from unit one higher than other follow it and blow out drain they put the other overflow drain out the eve so if it stars leaking someone notices it and it doesnt damage cieling but it sound like it needs imediate attention befor it does go to the overflow pan and damage your cieling. i hope this helps and good luck
Sep 29, 2009 | Amana PTC153B35AJ Air Conditioner
Think I have pinhole leak in 1/2'' copper water pipe
What type of pipe are you looking at?If it is copper then you can fine someone to solder it.If it is plastic pipe with glue joints,then you get some glue call rain and shine,clean first then apply wait a few minutes.But turn the water first.
Mar 14, 2009 | Plumbing
Heating & Cooling Logo
37 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Marvin
Marvin
