Question about Ainol Novo 10 Hero 10 Inch Tablet Pc IPS Dual Core 1.5GHz 16GB Bluetoo
Ainol Novo 10 Hero Tablet won't turn on/off on power button... it only works from reset button... also auto rotate doesnt work... Also whole tablet gets stuck always after 10min useage... ideas???
Posted by tommi_syrjal on
Kin yawn
    New Friend:
    Problem Solver:
  • 5 Answers
I have same problem as you have: the on /off switch completely not work . It cannot start only way use the reset pin then cannot off.Mine also has freezing problem.I went to setting then go to factory reset erase all my data. The freezing gone but the on / off switch still not work then I think this could hardware problem. Only way is open it up.Since this is a traumata act I have to use as the last act.Meanwhile I set the display screen close in 2 minutes when want to stop it.Any one here have any better idea please help.
Posted on Jun 01, 2013
1helpful
Ainol Novo 10 Hero 10 won't turn on :( it appears dead :'(
Sounds like it is not charging.
The unit will power on momentarily if low batter but power off straight away
Get an electrical competent person to check the output of the power unit or use know good unit.
Will not turn on
If tablet keeps burning out charges it is due to the fact that an internal short in the tablet is making the charging unit exceed its parameters and allowing it to burn itself out. The issue is with the tablet, not the chargers.
My ainol novo hero is frozen on home screen
The simple way to tempary solve this problem by just use a pin to insert to the small hole next to the power supply hole.this will turn off the set and start from begining(not reset to factory setting).If your problem back again then need to consider to go to backup and reset to reset to factory setting.It will lose all your data.If still not work contact the factory and install update firmware./
4helpful
3answers
try pushing in the mic button with a safety pin. That used to work on mine, now mine wont turn on at all. : (
Ainol Novo 10 Hero 10 Inch Tablet Pc IPS Dual Core 1.5GHz 16GB Bluetoo Logo
Top Ainol Tablets & eReaders Experts
ADMIN Canada
ADMIN Canada
Are you an Ainol Tablet and eReader Expert? Answer questions, earn points and help others
