Question about Unitech PT630 Portable Terminal
Reset unitech 630 - Unitech PT630 Portable Terminal
    New Friend:
ERROR INVALID APPEARS ME PORTABLE TYPE (HT630) IN A PT630 UNITECH AS I CAN SOLVE?
Posted on Mar 17, 2016
Mini123sc reset tool
hi, mini123 is not manufactured by Unitech.
you can reset the password by the official distributors only. We are one of the distributor for mini123 please check our website for details
Jun 02, 2014 | Unitech MSR 206-33 (msr206-33) Magnetic...
I NEED DRIVERS FOR MSR206X...PLEASE?!
Please find the Driver download link for Unitech MSR 206-33 Magnetic Card Reader
ftp://ftp.ute.com/Support/Software/MSR206%20USB%20Driver.zip
Its absolutely free, directly from unitech website.
Kindly vote if my solution solved your problem.
Jun 03, 2011 | Unitech MSR 206-33 (msr206-33) Magnetic...
My TomTom GO 630 is frozen on locating a GPS signal. How do I reset
Mine does this about once every couple of weeks. It just requires a "soft reset." To do this you just take a pin or paper clip and press the reset button located on the bottom of the TomTom Go 630 to the left of where you plug in your charger/usb connector. This is a "soft reset." None of your settings are changed... it's just like rebooting your computer. It just clears your temporary memory (like RAM) so all it would possibly lose is your current route if you had just set one. You probably can't since yours is frozen but DO NOT go through your device menu screens and "reset to default" because you will lose all of your settings and saved locations that way.
Apr 21, 2010 | Tomtom Go 630 GPS Receiver
Where can I get a replacement battery for the PT 930? It is a 307v 1800mAh Li-ion re-chargable battery.
We have plenty in stock, please contact me. You can always contact me by phone or email 630-622-2024 [email protected] Please visit our website www.legacyglobal.com
Oct 20, 2009 | Unitech PT930 Portable Terminal
Total available char can be scan
The number of characters read is defined in your application and the width of the printed bar code. Also the width of the laser or ccd. One program to develop applications JobGen Plus de Unitech.
Roberto Martinez
Aug 16, 2009 | Unitech PT630 Portable Terminal
I still can not find the cold boot button on my PA962 unitech .
That's a procedure. Read the below mentioned :-
http://www.unitech-utp.com.tw/content/service/FAQ.aspx?&Page=6
Thanks.
Jun 13, 2009 | Unitech PA962 Portable Terminal
Unitech pt630d reset code
That message which your scanner is displaying is the normal and correct mode in stdby, there is no problem with it.
If the scanner says "bad command" is because you are pressing the "enter" (ENT) key without any command selected before.
Bye.
Feb 12, 2009 | Unitech PT630 Portable Terminal
Sharp OZ-630
Do an ALL RESET. The only way i know of to do it is to hold the ON and Reset at the same time. Then select yes at the promt. Then wait 2 mins and take out batteries. Reinsert and turn on. it will re-format. This is the only way i know of how to ressurect it, but it deletes ALL you data.
Thanks
Aug 18, 2008 | Sharp Wizard OZ-630
Unitech pt630 scanner
Hello, Do you still need the solution? You can warm reset and exit the kermit mode, and then the download ur data using PTComm.
Jan 06, 2007 | Unitech PT630 Portable Terminal
Unitech PT630 Portable Terminal Logo
405 people viewed this question
Top Unitech Computers & Internet Experts
Ekse
Jeff
B.Th. Pluijm
B.Th. Pluijm
Are you an Unitech Computer and Internet Expert? Answer questions, earn points and help others
