Question about RCA R52WM24 52" HDTV Projection Television
RCA R52WM24 was watching tv the screen went very dim almost black then back on then off, this time lost picture sound and tv turned off. tried turning back on, power light came on for few seconds or
Seems like it just lost all power
Posted by Justin on
Sonny Berry
  • RCA Master
  • 8,617 Answers
The deflection board has failed. You would require the ITC222A deflection board which is the second board listed on the following page which has a warranty and comes with installation instructions
http://tvrepairworld.com/rear_projection_tv_circuit_boards/rca_circuit_boards
Posted on Apr 09, 2013
5 Related Answers
Slinteriors
Sonny Berry
  • 8617 Answers
SOURCE: 52 RCA DLP 1080P Television with NO picture and buttons flash
IF you would like help diagnosing your set. Go to the enclosed link. They have the service manual for your set and offer unlimited chat support for only 29.99. Just click on your sets manufacturer and you will see your model. Then click on the contact us link and provide your email address and they will email your manual and instructions on how to obtain your support. I am one of their techs. This manual contains step by step procedure for troubleshooting Your RCA DLP Light Engine
http://servicemanuals.vstore.ca/
Posted on Jan 15, 2008
Anonymous
  • 5 Answers
SOURCE: My rca tv d52w17 won't turn on.
Sounds like a faulty power inverter to me.
If it's covered under warranty, take it back to where you got it and ask them to cover the warranty for you.
If it's not under warranty, take it to a local electronics repair store that deals with TVs. Get a quote from them on the amount to repair it.
If it exceeds a third the amount you paid for the TV in the first place (ie if the TV cost you $1,200 and the bill exceeds $400) you're better off to get a new TV.
Posted on Apr 19, 2009
ginko
Ginko
  • 19396 Answers
SOURCE: A repair question for the RCA M50WH74S
If the TV goes in standby, then it is in protection mode.
Ensure also that the fault is not coming from a faulty receiver box sending
bad signal, check if you get same problem on DVD with no receiver box
connected.
Try first leaving the TV power cord unplugged for some times, let say one hour or so.
The flashing light indicates a diagnostic state called protection.
When the TV goes on protection there are only two possible causes.
1The internal circuits are jammed because of electrostatic charges accumulating on capacitors, or because of a wrong voltage read by the main chip on your monitor controller board. this started the protection circuit.
2 The protection circuit detected a wrong voltage or abroken contact, identified an internal fault and kicked in , starting the flashing light.
If you are in situation one, then the TV will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
If you want to DIY you find parts here,
All: Appliance parts, electronics parts & more from PartStore.com
Encompass Parts Distribution
LCD/Plasma Electronic Replacement Parts: Plasma & LCD TVs, Appliances |
On LCD Pay particular attention at inverter and power board, power board can be inspected looking for bulged or leaking capacitors, then tested with a multimeter. The inverter is more difficult to test , there is need to read voltages, should be done by a tech. Also the LCD controller board can cause same problem
On Plasma, test Sustain (Ysus/Zsus) / Buffer boards , cables to plasma, digital board and power board.
On Rear Projection : check lamp, lamp ballast, power board, and convergence.
On CRT TVs, check ballast , flyback transformer, CRT, Tuner, Convergence.
Posted on May 05, 2009
fillmore85
Tom Fillmore
  • 62 Answers
SOURCE: My RCA Bigscreen HDTV will not turn on.
If this is similar to the d52w20 then I almost garantee you need to replace a capacitor. You can check to make sure that's what you need by unplugging the tv, taking off the back cover and feeling the top of 3 capacitors. On my d52w20, CP150 (rated at 2200uf 16V) was blown and the top was bulged out. You should also check CP120 and CP114 to see if either are blown. I don't have a clear picture of where it's located, but I have a picture of what you should see after you take off the back cover.
http://i265.photobucket.com/albums/ii209/fillmore85welder/KodakMoment003-1.jpg
In the middle of the picture you see an aluminum heatsink in the shape of a 'C' with the opening facing away from you. That is where CP150 is located. CP120 and CP114 should be located nearby, but if you can feel a bulge on any of the tops of those 3 capacitors replacing them should fix your problem. Replace the existing capacitors with a higher voltage rating of either 25v or 35v.
"4 capacitors on the power/deflection board. CP110 220uf 200v. CP120 220uf 35 Volts. CP114 220uf 35 volts. CP150 2200 16 volt. also check entire delfection board for cold solder especially around flyback. bad connections here can cause problems like some of the fp fuses blowing and cutting off convergence supply"
Posted on Jun 04, 2009
Anonymous
  • 647 Answers
SOURCE: Replaced the fuse in RCA R52wm24 and resoldered
The fuse blows when there is aproblem with the convergence board - if the TV just had issues with the convergence b4 you soldered and replaced the fuse then the set should not be dead - I would check all plugs especially the 2 flexible (short) cables that jump the (ssb) two boards together. Do you hear the HV trying to start (a little chirp sound near the flyback) If so the set is in shutdown mode if not then power supply problems are usually the cause - check for swelled capacitors in power supply.
Posted on Oct 06, 2009
Testimonial: "Amazing how you can pinpoint an issue by reading text from someone who has no idea what they are doing! Great job! It was one of the two flimsy cables"
I have a RCA 42" model 42pa30rq and i was watching the tv and the picture goes out. I was trying to trouble shoot the tv on the y and x board but the x board is connected to the y board but still no type...
How much lld are you? How many Plasma sets did you repaired so far? Do you think repairing a plasma TV will be very like eating a ripe banana?
Contact any well experienced service technician; man.
"YOUR WORDS above REFLECTS YOUR IGNORANCE IN SERVICING SUCH ADVANCED TECHNOLOGY SETS.
What else to say? http://electronicshelponline.blogspot.com/
Oct 12, 2016 | RCA Televison & Video
Lost entire picture, sound and everything else OK
check the invertor boards resistors they power the back lights
also check for any capactors that have blown (raised tops) they look little bateries
Dec 12, 2009 | Element Electronics FLX3220F 32 in. LCD TV
38 '' RCA TV XBOX Model 36V550T, lost the picture
Does it only happen when you use your Xbox?
Try pulling the cable in and out between the TV and Xbox
Dec 05, 2009 | RCA 36V430T 36" TV
Picture went off on rca flat screen while watching still have sou
That probably happened because something hit the TV and broke the line for pictures to get through, or because a wire in you TV is bad and doesn't wanna work. This happened to my TV every few days. What I did is give it a few whacks every now and then on top of it and the vision came back, but don't try that if you think your TV is fragile. Yes I know its sounds stereotypical but it actually sometimes works.
Well, good luck!
Jun 04, 2009 | RCA TruFlat 27F520T 27" TV
RCA Model Number R52WM24
Is this a projection set? If so you simply need to set the convergence. Otherwise I would try to return it to the retailer and exchange for different manufacturer.
Apr 22, 2008 | RCA R52WM24 52" HDTV Projection Television
Tv screen goes black
No, if the picture of your tv screen is clear when when you watching. the troble of your tv is looseboard, and you replace your CRT socket too.
Apr 16, 2008 | Sony KV-35V35 TV
No life
sounds like the sat receiver not the tv.
Mar 23, 2008 | RCA F36669 36" TV
RCA 37'' has sound but no picture
1)confirm service # on back of tv 2)Is sound from tv or surround system? 3)suspect bad flyback xformer.
Sep 01, 2007 | RCA F36665 36" TV
RCA R52WM24 52" HDTV Projection Television Logo
147 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
