I have unplugged the range.
SOURCE: burner will not turn off
I will need the complete model #. There should be a sticker near the bottom front behind the drawer. Can't use the # that is on the owners manual.
SOURCE: cooktop burner doesn't switch between small and large
The burners are controlled by switches, that are the one you turn when you turn the knob. Iwf the burner does not switch to high mode than you need to change the switch.
The switch for your appliance has part number:
WB21X5243
You can by the part from manufacturer clicking here.
Here is an exploded view of your kitchen panel.
The switch is indicated with number 3 in the picture, There should be at least ttwo of them, depending on the model. That is what you need to replace.
Its price is $40.50 from GE.
If our posts had been helpful do not forget to accept the solution.
Regards
SOURCE: GE JBP64 Radiant Range - won't work
This is a very strange one, and you don't say how old this unit is or how long you have had problems with it, but most likely you have a poor electrical connection. Turn the breaker off and unplug the range. Remove the cover over the receptacle you just pulled the plug from and check all the electrical connections. If all OK, check the electrical connections where the cord attaches to the range. If still OK, inspect additional range and household wiring to range, including the connections right on the circuit breaker.
SOURCE: GE Profile JB 968 Hot Cooktop Indicator Light Always On
Temporary solution to turn off the indicator lamp - put a wet rag with an ice pack on top on the middle section of the cooktop.
The thermal sensor will trip off the lamp.
SOURCE: ge profile gas range. one burner with no clicking and no ignition
Try one to light one of the other burners that work and watch the electrode on the burner that does not light and see if you have spark when you here the clicking nois. (( most gas cooktop spark ignitor all spark at the same time, even if your only trying to light one burner ))
If you do have spark, Then the Ignitor switch is bad.
If you don't have spark then your spark modual is bad.
