Driver door lock is not locking
SOURCE: keyless entry code for 2003 lincoln aviator
Every car different, call an auto rescue or towing company, the trucks are usually equiped with slim jims, that can be used to gain access to your vehicle.
Hope this helps.
Ed
SOURCE: key pad on door
I'm assuming you bought the car somewhere other than a Ford/Lincoln dealer (which is OK) because I would expect a Ford/Lincoln dealer to provide all three keys, two remotes, a manual, etc as well as the lock code. I too just purchased an 07 TC. The dealer provided the code for me, but said there are three ways to determine the code (in order of preference):
1. Usually there is a white unlabeled paper sticker with the code number (5 digits) on one of the trunk hinges, but often times it is removed when the car is detailed or the previous owner may have removed it.
2. There may be another similar sticker on the control unit on the right side fender under the hood, again same scenario as above.
3. Any Ford/Lincoln/Mercury dealer can pull the code from the car computer, hopefully for free or nearly free if the car is still under factory warranty, regardless of where you purchased your car.
If you're stuck with option three, particularly if the factory warranty is still good, and even if it isn't, put on a clean shirt, be nice but make 'em step up. After all, even though we may have paid alot less now, these cars MSRP was $45,000 and up only a year ago so they should still treat you and me like gold.
Best of Luck!
SC442299
2007 Signature Limited
4.6L Flex-Fuel (E85/Gas)
Light Ice Blue MetallicClearcoat
Slate/Dove Interior
SOURCE: 1995 Town Car Signature driver side power lock doesn't work
Yes there is a fuse, from the eletrical diagram i am seeing power comes from the power distrubtion box and also fuse in the Fuse box,
Check your fuses for any blown ones. Im seeing a 15amp and 20 amp fuse and a 40amp feed from the distrubtion box.
SOURCE: How do you reprogram the keyless door lock code?
The Keyless Entry Module is located inside the drivers side door.
1/2-- memory seat position 1
314-- memory seat position 2
5/6-- memory seat position 3
SOURCE: forgot the factory's code for the door lock pad
The original code is 5 digits next to the fuse box towards passengers front tire on a white label on a black box move bottom 2 wires to see last number.
