Question about Kenwood Multi Pro FP730 Food Processor
I have a Kenwood FP703 Mulitpro. Attachment 2 which is the centre spine that sits on the base seems to be loose and my processor wont work. Is there a way to click it in
Posted by catherine carew on
Kenwood service center kerala
Hi, Hope this helps.
Kenwood Service Centre Cochin Address Address :
Pukalakattil Building,
Mahakavi Vailopilly Road,
Palarivattom
City : Cochin
Kerala, India.
Pincode : 0.
Kenwood Cochin Service Centre Contact Details :
Phone Number : 9349519613
Website : http://www.kenwood.com/india/
Dec 13, 2014 | Kenwood Food Processors
Kenwood KM336 no power to beater or slow speed outlet
Hi. You have a broken gear in the gearbox either the first motion gear is loose on its shaft or less likely the vertical big gear is loose on its shaft. independent spares for the gearbox are available or complete gearbox
Aug 02, 2012 | Kenwood KM336 Chef Food Processor
Is there actually any one person in the entire world who knows how to take a Kenwood FP510 processor apart to change the drive belt? There are lots of queries on the internet but no solutions. Somebody...
I have solved it at last! Remove the 5 screws on the bottom. There are 2 more screws (which may be blackened with oil) located through the grille directly below the motor. They're stumpy little things with gripping washers. I had to bend the plastic grille thingys to get screwdriver in. Once released, these will enable the whole base to be removed. Then there are 3 screws to get the plate off to put the new belt on. Put the belt around the big cog. Replace the 3 screws of the plate. The motor drive is loose now so you can angle the drive cog to attach the belt to this. Using gravity by turning the processor on it's edge you should with some fiddling be able to put the stumpy screws back in - took me a couple of goes. Replace the 5 screws and robert is a very close relative.
Jan 29, 2011 | Kenwood Food Processors
I have a kenwood gourmet fp505 - how do I use the whisk attachments? Also where can I get a manual for this product?
I was wondering too how to assemble the Whisk, saw your post, searched again for the manual and happily found it buried in a drawer! Here is a copy of section on the Whisk attachment.
Nov 18, 2010 | Kenwood Food Processors
I need instruction manual for Kenwood Chef attachment A797
Could you please email me a copy as well the service book
Jul 08, 2010 | Kenwood Food Processors
The Blender attachment will not turn, just grinds and smokes.
The motor shaft that spins the teeth that are on the base of the blender may be frozen up for some reason. If you purchased the duet within the last 3 years and have a receipt, call Cuisinart to get it repaired in warranty - even if you don't have a receipt, your serial number may still save you. If you purchased it more than 3 years ago, let me know.
Mar 12, 2009 | Cuisinart BFP-703 SmartPower Duet Food...
Wolf Gang Puck 620 Food Processor - Broken Blade - Need replacement
You guys with the Wolfgang Puck processor, need to go to this website, they have what you need but not what I need, I need the spindel, the blade is $9.99 www.wpcookware.com
Jan 22, 2008 | Wolfgang Puck BFPR0015 Food Processor
Kenwood Multi Pro FP730 Food Processor Logo
48 people viewed this question
Top Kenwood Food Processors Experts
ThaMp3Doctor
ThaMp3Doctor
Ross Keen
Are you a Kenwood Food Processor Expert? Answer questions, earn points and help others
