This might help. This is the thermal fuse you need if you need a replacement. Cost is somewhere around $25.00
PartSelect Number PS342838 This part
is used as a safety device to protect the dishwasher circuit from
overload. If the temperature gets to high it will shut off the
electrical current to the heating unit in the appliance. This part works with the following
brands: Whirlpool, Admiral, Estate, Inglis, Kenmore, KitchenAid, Roper,
Maytag, Kenmore, Admiral, Crosley, Jenn-Air, Hardwick, Magic Chef,
Amana, Caloric & Glenwood.
Thermal Fuse
This part fixes the following symptoms:
See part 26 in the diagram
Item #2986 (OEM Part)
$10.70
Thermal fuse. If the dryer overheats, this device stops the flow of electricity to the heat source and/or the entire dryer. It is located on the blower housing and cannot be reset. The most common cause for overheating is a vent tube clogged with lint, a birds nest or other debris.
Manufacturer Number 3392519
More
In Stock
Quantity:
http://www.repairclinic.com/PartDetail/Thermal-Fuse/3392519/2986#repairHelpVideoTabs
