Question about Visonik Car Audio & Video
High input wiring - Visonik Car Audio & Video
Hi audi a3 2.0t bwa two faults p2127 and p2122 what can cause this problem
code p 2122 has three reasons
1--accelerator pedal position (APP) sensor---switch D--low input==causes wiring short to ground --APP sensor /switch
2---throttle position(TP) sensor /switch D--low input===causes ---wiring short to ground--TP sensor/switch
3---engine control module (ECM) idle control---high input===causes --wiring short to positive ---TP sensor---ETS control module
code p 2127 refers to APP sensor--switch E--low input===causes wiring short to ground --- APP sensor/switch
also refers to TP switch E--high input====causes wiring short to ground ---TP sensor switch
Jan 31, 2018 | Audi Cars & Trucks
Their are 2 power wires,2 negative wires and 2 rem wires...how is this wired..im getting ready to get this put i
Some amps come with extra, power,rem,ground, so you can , power up another Amp Without runing to many wires. , or using a power block.like a parallel, being your 1st Amp your power block, and your remote, ground .
Apr 03, 2016 | Jensen JXA8BA2 Amplified Subwoofer, Max...
Need to know how the two yellow and two orange wires hook to
The yellow and yellow/black wire (left) and orange and orange/black (right) are high input speaker feeds to power the amplifier. You either connect high input feeds or the low level phono inputs! Not both!
Sep 05, 2015 | Car Audio & Video
High level input question
High level input is used when no RCA output are present on the head unit. You would wire the head unit speaker wires to the high level input.
Mar 18, 2014 | Rockford Fosgate Punch 301S Car Audio...
Amp works on low side and full no high side
high level inputs are for speaker level inputs.Like if you used speaker wires right off your radio for input.Low level inputs are rca type inputs
Dec 19, 2012 | Performance Teknique Icbm-770 Monoblock...
Jet sound equalizer js 214 wire color code
Black wire is ground, Red with 5a fuse is hot. Green/black is L Ground BTL, Grey /black is right ground BTL, the RCAs are left and right low level inputs. Then there is the 5 pin connector. It has a red wire for +12v, two black wires for input grounds, a green wire for left Hi input and a gray wire for right high input. If you install using traditional common ground high level, then you don't used the two BTL wires. Just connect the wires from your 5 pin connctor. If you use the low level RCAs for inputs, then you only need to connect the red and black from your 5 pin connector.(Plus the main red and black) Make sure the switched on the bottom of your EQ are set correctly. COM for common ground and LOW for RCA input or High for Green/Gray wire input. If you are using a floating ground the select BTL and connect the two BTL wires to the floating grounds of your stereo. There is also a line input adjuster so you can adjust your input sensitivity to match your reciever. I have the owners manual if you have any other questions.
Feb 01, 2012 | Car Audio & Video
What wires do I hook up to the high level in plug that came with my dual xp2100 2 channel amp
First, know that you need either high level input or low level input, but not both. Low level input is preferred (RCA cables). If you must use high level input because your head unit doesn't have RCA jacks, you connect the speaker outputs from the head unit to the high level input of your amp. The high level input plug probably has a black wire, this is "signal reference ground". A pair of grey wires which are right positive (grey) and right negative (grey with black stripe). And a pair of white wires, left positive (white) and left negative (white with black stripe).
Feb 26, 2011 | Dual Car Audio & Video
Where do these wires go
Hello sxy_spud,
Those wires are for the "speaker level" inputs to the amp. If you are using RCA cables from your head unit, you do not connect these at all.
If you are NOT using RCA cables from your head unit, the "pigtail" ends of the high-level input wires are usually connected to the rear speakers.
Hope this helps.
Sep 24, 2009 | Car Audio & Video
How to hook up a pyramid pro plus 4 channel pb-180px without using rca jacks for 6 by 9s
The pb180 has High Input receptacles on the back end. They are marked High Input and identified as Channels 1&2 left/right, and channels 3&4 left/right. You will need to identify all speaker wires coming from your head unit ( left front +&--) , and so on. You will be sending the speaker wires from the head unit to the pb180's High Inputs. In other words, the front left speaker wires(+&-) from the head unit will go to the High Input Channels 1&2 side, left input of the pb180, and so on, so the speaker wires coming out of the head unit will need to be cut. And LABEL all sets of speaker wires before you cut them! Then on the OUTPUT end of the pb180, you will be sending the wires back to the the respective speaker wires which are going to the speakers. So it's out from head unit to pb180 and out from pb180 to speakers.
Hopefully you have the plugs that Pyramid uses for the speaker wire inputs to the amp. If not you have to get creative, and make up terminals to fit into the input receptacles. Maybe a wire terminal from Radio shack will fit those pins..
Also, if you go on line: Google search "Pyramid auto amps" and click on "SEARCH" (upper right hand) of their Web Page. Plug in your model number like this, pb180, and you'll be able to download the manual for this amp. The manual has a full description of the wiring options.
Hope this was helpful and Good Luck!
Jul 27, 2009 | Pyramid Audio Players & Recorders
Sony xplod amp xm-1652z high level input connection
First off, if you're using RCA preamp connections from the head unit to the amp, you don't need to put anything into the high level input connector. But if your head unit doesn't have RCA preamp outputs, then connect the front left to the white (+) and white/black stripped (-) wires and the front right to the grey (+) and grey/black stripped (-) wires. There is no need to connect the rear speaker outputs of the head unit to the high level input of the amp.
Apr 17, 2008 | Sony Xplod XM-1652Z Car Audio Amplifier
Car Audio & Video Logo
Top Visonik Car Audio & Video Experts
xxxxxx xxx
Are you a Visonik Car Audio and Video Expert? Answer questions, earn points and help others
