Question about Vulcan Heating & Cooling
Vulcan ducted heater series el90-31 thermocouple type replace
5 Related Answers
Anonymous
  • 236 Answers
SOURCE: need parts: pilot assembly and thermocouple
THe thermocouple either has 2 wires or a coppr tube going to the gas valve. They can be bought at a good hardware store or a plumbing supply. The length of the wires or copper tube will be the determining factor as to which one you need. As these thermocouples, when heated generate a small electric charge tha keeps the gas valve open. Should cost no more than $10-15 USD
Posted on Oct 10, 2009
Anonymous
SOURCE: I need instruction for a vulcan ducted gas heater
ineed to unlock my sim card said puk code and idk
Posted on Feb 11, 2010
sloooo44
Michael Youngman
  • 296 Answers
SOURCE: Is vulcan duct heater still in existence?
Yes. Vulcan heater company is still making heaters. Here is the link. http://www.vulcanelectric.com/
Grainger is a direct seller of Vulcan heaters, so you chould be able to give them a call, explain what you need or giver them a part number and they will be able to get what you need.
Posted on May 12, 2010
male_28_cam
Aruna Singh
  • 1555 Answers
SOURCE: My Vulcan CX90 ducted heater works fine other than
80 Series Burner Base. PART 1318011
Here is the complete listing
www.reece.com.au/new/pdf/products/Reece_Gas_Reference.pdf
The problem is that this part number is not available on net for sale.
Posted on May 23, 2010
Anonymous
SOURCE: we have a Vulcan Ultra high efficiency gas ducted heating
Gas ducted central heater won't switch on all of a sudden
Posted on Sep 21, 2010
Bonaire vulcan comfort control
No it cant really be fitted as the evap system uses much larger duct and also in some cases people use a different type of duct that when running a gas heater threw it it tends to melt with the heat. Your best option would be to get new ducting that way you can size it correctly so you dont have air alance issues down the track.
May 10, 2014 | Heating & Cooling
Pressure switch replacement
Standard Appliance, Appliance parts incorporated, yhese types of places.
Jun 28, 2013 | Vulcan AUW230A Heater
My vulcan ducted heating unit blows cold air for approx 1 minute when turned on then stops and try's again after approx 1 minute,it does this several times until ignited.It is obviously an ignition...
Two things have to occur here:
1) The ignitor has to light off the gas. A bad ignitor, or dusty burners can prevent ignition.
2) The thermocouple has to be in the flow of burning gas to prevent a safety shut-down, and has to be working.
And the obvious: you need pressure in the gas line, and the gas valve needs to be open.
Hope this helps you locate the problem!
Aug 14, 2010 | Vulcan AUW230A Heater
My Vulcan CX90 ducted heater works fine other than the base of the ducted heating unit is coroded and needs replacing. This the part that the unit sits on which connects to the return air and outlet pipe....
May 23, 2010 | Heating & Cooling
Ive got a Vulcan Gas dusted Heating system -
Possibly a bad thermocouple or whatever is sensing the flame. If its a flame rod you can clean it with steel wool. Let me know what you find.
May 05, 2010 | Heating & Cooling
The pilot light has gone out on an old Vulcan gas wall heater. How do I turn it back on?
You probably need to replace the thermocouple before you will be able to get it lit.
Oct 14, 2009 | Vulcan Heating & Cooling
Vulcan CX ducted heating
sounds like the thermocouple (that sensors the heat) may be faulty.
you will need a licensed gas fitter for repairs
Feb 19, 2008 | Heating & Cooling
Heating & Cooling Logo
71 people viewed this question
Top Vulcan Heating & Cooling Experts
Paul Carew
Vernon Taylor
john h
Are you a Vulcan Heating and Cooling Expert? Answer questions, earn points and help others
