Washer flashing door, will not shut off once turned off or unplugged
We found a way to reset the computer and solved the problem.
1. Press and hold pause turn off machine and turn back on holding pause all the while.
2. This should reset the computer. All lights will light up on LCD display.
3. Release pause button. Turn off machine, turn back on and begin a new wash cycle.
woo hoo!
I was able to reset the computer but that didn't fix my issue.
What did fix the issue for me was to drain the water that had collected from a previous cycle. The washer made a weird noise for a bit, finished the cycle and then worked fine after.
Although error 1000 isn't on this site. There is a link to a youtube video regarding maintenance of your washer that will tell you how to drain the water. Be careful as there might be a lot of water in it.
Blomberg Washing Machine Error Codes
I have Blomberg WM87120 NBL00 Product code 717518110 and had flashing Lock in display. Bought and installed new lock and no change. Display still flashing lock. Used above procedure and every is working now. Only thing different to above was when repowered while holding pause switch two number came up. I didnt write them down, when I let go of pause button the all lights came on the display as it states above. Turned off then back on and its go to go. .Dont know if new lock made a difference.
Wish I had found this procedure first
