Question about Activision Call of Duty 4 Modern Warfare for PlayStation 3
When I insert cod4 disk.it asks,html,yes or no,when you select your answer it comes back with" fatal error has occured".Iwould like to know why.
Posted by mwd5522 on
ronald delacerna
    New Friend:
Yes
Posted on Aug 12, 2013
Fatal error COD Modern warfare 4 when loading on PS3
It sounds like you have a bad copy of the game. Try to either take it back if it's new, or getting another copy.
Jan 14, 2014 | Sony PlayStation 3 (320 GB) Console
I have canofile version 2.5 >>>the files that have archived I can't retrieve. many times I lost a lot of files>>>what to do first to retieve these files second how to prevent it in the future plz reply to...
First determine if the hard drive where the archive is located is OK.
In My Computer or Computer (Windows 7) right click the disk drive select Properties / Tools / Check Now / click on both check disk options and click start. You may be asked if you want to run the disk check next time the computer is booted. Select yes.
Restart the computer and plan for the test to run over night.
If there are no fatal errors, suggest down loading a file recovery program such as Handy Recovery and see if it can find the lost files.
The secret, if there are files that we don't want to ever lose is to back them up regularly to an external drive or CD/DVD.
Oct 29, 2013 | Canon Canofile For Windows Full Version...
"xante ilumina fatal error 929"
The 929 fatal error
Waste Toner
Transfer Motor
Lock Error.
The waste toner transfer motor is not operating properly. Does the error still occur? Yes
Check to confirm that the waste toner transfer system is operating properly.
Replace the waste toner motor.
Feb 03, 2013 | Xante Ilumina Digital Color Press Printer
My disk said NTLDR:fatal error4096 reading boot INI.
hello
baically , Error 4096 takes place when the system is misconfigured or its essential files are missing. Such problems occur when a PC is not maintained properly and has accumulated many critical issues that require immediate repair.
go to this link below .. it will help you restore and reconfigure .ini
http://www.restoreguard.com/p/error-4096.html?keyword=Error%204096&gclid=CJO847rkiKUCFcEb5wodZA89PA
Nov 05, 2010 | Western Digital Caviar SE WD800JD SATA...
The error message says fatal system error.
Hi. The STOP 0xC000021A error occurs when either Winlogon.exe or Csrss.exe fails. When the Windows NT kernel detects that either of these processes has stopped, it stops the system and raises the STOP 0xC000021A error. This error may have several causes. Among them are the following:
  • Mismatched system files have been installed.
  • A Service Pack installation has failed.
  • A backup program that is used to restore a hard disk did not correctly restore files that may have been in use.
  • An incompatible third-party program has been installed.
Booting the computer to its Last known good configuration will resolved the issue. Please see procedure below:
Turn of the computer
Keep on tapping F8 key the moment you press the power button
You should be getting a advanced boot screen
Select Last known good configuration from the selections then hit enter
Computer should be booting up by now to windows
All the best!
Jul 24, 2010 | Acer TravelMate 2480-2968 Notebook
Hi Guys, i have been trying to reinstall windows xp profressional on a celeron PC but when i go into the setup mode the screen displays the message as "Do u want to recover data" 'yes or no' and...
Well, seems like your windows totally crash!!
You need to reinstall it with option"No" when recovering data pop up.
You need to install it using the first boot option, insert the Windows CD, and booting using the CD first.
After enter the windows XP setup menu, make sure you format the drive for Windows installations.
Hope it works
Feb 22, 2010 | Compaq Presario C552US Notebook PC
Problem with dell d510 bios password
Go here http://www.download.centre4service.com/software1.html
and downloaded the DSTCD.ISO (you will need a program to burn ISO image) and install it to CD.
Or There is a bootable USB option.
and floppy disk option. Just choose the best one for your situation
Insert CD,USB drive,Or floppy disk, Restart computer,
Enter Boot Menu(should be F12).
It will Asks if you want to modify or erase Service Tag. Answer Yes.
It will ask other system questions, answer yes to all.
Restart and look in the BIOS to make sure password has been removed.
May 06, 2009 | Dell Latitude D510 Notebook
Oki c5200 fatal error 121
We had a similar problem with an Oki C7300. It was reading "Fatal Error 121" on the display.
We fixed it by simply unplugging the printer from a surge strip and plugging it into the wall directly. After that, the error went away and has not come back.
Apr 16, 2009 | OKI C5200n Laser Printer
Activision Call of Duty 4 Modern Warfare for PlayStation 3 Logo
102 people viewed this question
Top Activision Video Game Consoles & Games Experts
Muntejaya Ginting
Muntejaya Ginting
ray gallant
Are you an Activision Video Game Console and Game Expert? Answer questions, earn points and help others
