Question about Mitsubishi Televison & Video
How much does an IC convergent cost on the average for a mitsubishi tv
Posted by rita hartman-vigil on
Sonny Berry
  • Mitsubishi Master
  • 8,617 Answers
You can do it yourself for about 50.00 by installing the convergence repair kit for your model which are available from www.tvrepairworld.com that contain parts and the CD with instructions. A shop normally gets bewteen 175.00 to 300.00 for the repair depending on which shop you get to do the repair.
Posted on Apr 08, 2013
5 Related Answers
Anonymous
  • 3130 Answers
SOURCE: Convergence IC
The convergence IC's are black in color with white lettering on them and will start with STK. These IC's will be standing up and be about 2" X3" in diameter. These IC's will also be mounted up against a large metal device called a heat sink. good Luck
Posted on Apr 08, 2007
Anonymous
  • 14 Answers
SOURCE: convergence /ic chips
I got the convergence amps from www.electronix.com for $10 each, plus a couple bucks for some heat sink compound. I also purchased a good quality solder and a solder sucker while I was there. It's a good outfit and they were very responsive.
Posted on Jan 14, 2008
Anonymous
  • 208 Answers
SOURCE: CONVERGENCE IC'S
Just looking at this problem and solution and thought you should also be aware that everytime I find the convergence ic's failed on this unit there is a 5 amp cp (circuit protect fuse) on the power supply.
Posted on Feb 09, 2008
Buddy Sisson
  • 15 Answers
SOURCE: 3d look on mitsubishi ws-55511
Hi bluemags,
It is true that you should use a higher power I.C., I do that all the time. However, the one to use is the STK392-120. This one is rated at 5 Amps unlike the STK392-110, 150, which are both rated at 3 Amps. I have not checked the data sheet on the 180. They are all OEM, since Sanyo designed them all. Beware of generic knockoffs not made by Sanyo. The generic I.C.s do not have the quality as the Sanyo originals.
Best Regards,
MyTvGuy
Posted on Feb 10, 2008
tvrepairbiz
Paul Bruno
  • 63 Answers
SOURCE: Sony KP53S76 Projection TV Convergence IC Bad
Should be a 392-150 make sure you replace both.
Posted on Feb 15, 2010
Convergence is way off, Rt & Lf side of screen has red & blue around objects
Convergence IC's inside of your TV have to be replaced. Also some low value resistors around IC's could be burned as well.
Then convergence have to be realigned. This job require above-average soldering skills and cost around $300 if you hire TV repairman to do that.
Regards.
Russ.
Apr 04, 2010 | Mitsubishi WS-73907 TV
The picture looks like 3D on my mitsubishi projected tv
You may be having a convergence problem. Convergence focuses the different color guns of the tv. This is usually a way to set the convergence via your menu. If this doesn't work, you may need new IC chips. This is fairly expensive. It cost me around $300 last time I had it done and it was hard to find anyone to do it. Good luck!
Mar 07, 2010 | Mitsubishi VS-45609 TV
On my mitsubishi ws65909 I have a 2-2 power light error code, what does this mean? any suggestions, I tried to power it up and the power light comes on and then goes off after 15-20 sec's
the famous code error 2- 2 is for fault in power supply or faulty power supply board. this has to be checked.
and error 2-3 is fault in convergence ic.so both the error codes are near to each other.so check out both options. i advise first replace the convergence ic on the board and check.the cost of each convergence stk ic is near to $15 .there are two such ic on the convergence board and both has to be replaced.then check out.if the problem is same go for power supply board replacement.
the ic which you have to remove and replace is stk 393-110 both the ic looks same anve same number .
you can get the required board and components at ----- www.partstore.com -------- or from ------ www.radioshack.com ----
if you are not familiar with doing this you can get it done by local tv repair technician familiar with this model tv.
This will help. Thanks please keep updated.please do rate the solution positively .thank you for using fixya.
Nov 26, 2009 | Mitsubishi WS-65909 65" Rear Projection...
Mitsubishi 1080 hd ws-65809 wont power up
This issue is almost always caused by a faulty Convergence IC inside your TV. These chips heat up and can become damaged over time. The most common cause I have seen for the picture distortion is the heat of the Convergence IC weakening the solder connection to the TV circuit board. If you look on various messages board you will see people rigging wooden dowels and other items to apply pressure to the chips in order to correct their picture issue. This works because when the solder joint is weakened the chip becomes loose and vibrations or pressure will cause it to work or not work correctly. Aside from all that information the correct fix is to have the IC chips replaces on your TV.
The solutions for this issue are as follows:
1. located a tv repair shop that will replace the parts for you. I had the same issue with my 65" Tv and the quote was $350 for the labor and parts.
2. You can ordered the IC replacements yourself online by going to google and looking up a reseller of the STK392-110 Convergence IC that is inside your model TV. You will need 2 of them and they cost around $6 each. If you have the soldering skills to remove the old chips and install the new ones this is by far the most cost effective route. It is a fairly simple process and guides can be found online.
Mar 17, 2009 | Mitsubishi WS-65513 65" Rear Projection...
My Mitsubishi VS-50705 has an all over 3-D effect.
Yes it sounds to be convergence issue .
You have convergence problem in your tv . You need to replace convergence IC . YOu can get from the link below .
Convergence ICs
You need to replace both convergence ICs .It will cost you around $30 .
The IC number is STK392-110 .
Hope this helps .
Mar 03, 2009 | Mitsubishi VS-50705 50" Rear Projection...
Our TV (Mitsubishi WS65711) is 6 years old, and has recently started showing a blue ghost image on everything. It stopped for a while for a week or two, but started back up, and has continued ever since. I...
You have convergence problem in your tv as your local repair shop told you. You need to replace convergence IC . YOu can get from the link below .
Convergence IC can be obtained from the link
If you can replace it by yourself . If you take to repair shop they will charge you around $200 for this job. .
The IC number is STK393-110 .
You can get some idea on how to replace convergence IC from the link below
http://www.fixya.com/support/r704766-convergence_solutions
Hope this helps .
Feb 19, 2009 | Mitsubishi WS-65511 65" Rear Projection...
TOSHIBA 50H72 50IN. REAR PROJECTION TV BLUE COVERGANCE PROBLEM
you have a convergence ampliphier ic failing that will need to be changed and then adjusted
average repair cost for this are 280.00 to 320.00
Jan 20, 2009 | Toshiba 50H72 50" Rear Projection...
CONVERGENCE WILL NOT PROPERLY CONVERGED
you only need one STK393-110 Convergence IC and two 5Amp pico fuses. You can get the IC and the two fuses for less than 35.00 at the following link and they provide free installation instructions with pictures so you can easially do the repair yourself. Heres the link.
http://servicemanuals.vstore.ca/
Jan 19, 2009 | Mitsubishi WS-65712 65" Rear Projection...
WS-55819 Mitsubishi Rear projection TV Picture goes blurry
Convergence ICs are bad need to be replaced. You will need to replace both of them also check the resistors right next to the IC often 1 or 2 of them burn out when the IC goes.
Feb 26, 2008 | Mitsubishi WS-55819 55" Rear Projection...
Mitsubishi vs 60719 - Wavy bow in picture
Either a bad solder connection on your convergence module or a bad convergence IC. Repair costs will probably be in the $350-$500 range.
Jan 28, 2007 | Mitsubishi VS-60719 60" Rear Projection...
Televison & Video Logo
102 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Todd Hill
Todd Hill
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
