I have some movies downloaded to an external hard drive. When I try playing them through my Samsung HT-D4500 or HT-E4500, I get an error message: Cinavia Message Code 3, and the sound is muted. This keeps happening to interrupt the movie. Any suggestions on how to bypass this error? Thank you.
    Problem Solver:
  • 6 Answers
The cinavia is not an error. This means that Samsung suscpects that you dont have the proper licences to play that file.
Cinavia is a copy protection that is used in some Blueray movies, and this copy protection is not removed when the file is ripped from the BD disk.
If you play the file on a computer or some other media player that dont have cinavia protection enabled, then the file will play without problems.
I have a Samsung HT-D6750W, and the same problem apeared after a firmware update, think it happended between fw version 1012 and 1013.
There is no way to downgrade the firmware in these players, but some of them does support custom built firmware. After you get that custom firmware installed, the software will be more open. Then it will be possible to patch the needed files to bypass the cinavia.
But this is a complicated process which require a bit knowledge to linux. And doing stuff like that will involve a certain risk of bricking the device if you do it wrong, and it will certainly break any warranty.
But if you are still feeling comfortable with trying this, then go to the SamyGO and try to figure out if your model is supported or not. Here are a few links to help you get started. But before joining the forum and start asking questions, do read all the info in the wiki's and search for your questions in earlier posts first.
http://wiki.samygo.tv
http://wiki.samygo.tv/index.php5/Patched_firmware
http://wiki.samygo.tv/index.php5/ExeDSP_modifications
Posted on Jun 29, 2013
    Habit-Forming:
    Scholar:
  • 156 Answers
When you receive Cinavia Message Code 3, then it means that the audio track of your Blu-ray or DVD content contains Cinavia code. Without removing the Cinavia Message Code 3, you are not allowed to play or copy the digital content as you like.
To get rid of the Cinavia Message Code 3 on your player, you can try Leawo Blu-ray Cinavia Removal which is a program that can be able to remove the Cinavia protection with ease.
Posted on Feb 14, 2020
5 Suggested Answers
Anonymous
SOURCE: System Error
FYI...the best suggestion I've seen is to hold the channel up and play buttons simutaneously....thereby causing the machine to return to the "factory initialized" state. So far so good for me. We'll see. photog1
Posted on Dec 03, 2007
Anonymous
  • 22 Answers
SOURCE: screen says cant record copy protected movie
Is this a new problem or has it always been like this? The unit will throw that error message if there's a copy protection flag on the broadcast source.
To make matters worse, there are three flags a broadcaster can set. Copy Always, Copy Once, and Copy Never.
Copy Always and Copy Never are pretty self-explanatory but the Copy Once flag with this unit only works with certain media, namely DVD-RAM and DVD-RW in VR mode with CPRM (Content Protection for Recordable Media.
Copy Always flag should work with all media. I don't know of any easy way to figure out which broadcasts have which flag but try changing your media and recording mode first.
P.S. You may also want to reset to factory default settings by pressing FF and RW together on the player. Also make sure you're running the latest firmware.
Good Luck!
Posted on Feb 04, 2009
SOURCE: disc error "playback feature may not be available on this disc"
Hello arnita2211,
This error message is due to an improper format, that your dvd player can't handle. To correct this you need to use a program such as nero and in nero is a program called nero vision, that will recode the movie file into a dvd playable format.
You can download a trial of nero here
http://www.nero.com/enu/downloads-nero9-trial.php
You will have to purchase a license when the trial ends. Sorry we cannot give you a serial key for this as it is Illegal.
Thank you for trying Fixya!
Posted on Apr 08, 2009
darjr
Darial Jr Lasaria
  • 379 Answers
SOURCE: Error message
this mean that the player didn't recognized any external device connected to it.Check the external device setting.
Posted on Jun 18, 2009
Anonymous
  • 27 Answers
SOURCE: DVD player is saying "Wrong region"
region codes are as follow. Region 1 North America, Region 4 South America, Australia, Region 2 Europe, Region 5 Asia Major,Africa,Region 6 Asia Minor, Probably your DVD is from another region....hope this helps
Posted on Jan 01, 2010
How do I remove firmware or cinavia?
Can you give a little bit more info on this: Is it that you are having problems with viewing discs because of watermarks?? Or have you updated your firmware and it is causing problems? Here is a link to where you can download your manual if you don't have it: http://www.samsung.com/us/support/owners/product/HT-E4500/ZA
Aug 24, 2015 | Samsung HT-E4500 5.1 Channel Blu-ray Home...
From USB port unable to play the movies. The message unable to Protect, while opening movies from USB/ external Hard disk to play on TV Hisenese ER31607A
May be Speed of USB flash drive is equal or below Class 4.0. Try to check with Other higher speed USB Flash Drives. (Class 6 or Class 10 or HDMI)
Mar 21, 2015 | Hard Computers & Internet
IO error when movie starts playing and stops
IO error means Input/Out error. It looks like your mediaplayer is not liking your external hard drive. Make sure the video is supported by the mediaplayer, otherwise you will need to convert it to a video file that the player supports.
Nov 22, 2013 | Computers & Internet
How do I play downloaded movies from Samsung M3 Portable hard drive to tv
Most TVs will play AVI movies from USB connected drives except Sony TVs. Sony has prevented downloaded movies playing on their TVs.
Jan 27, 2013 | Computers & Internet
Ht-e4500 region free
None of these procedures work on the E4500 Samsung.
Dec 31, 2012 | Samsung HT-E4500 5.1 Channel Blu-ray Home...
Samsung ht-d4500 region code
I just leave this message to tell you that this really worked for my blue ray samsung ht-f4500/zx in Mexico City. Thank you very very much. Cheers
May 02, 2012 | Samsung HT-D4500 Blu-Ray Home Theatre...
When I try to play a movie with my samsung se so84d drive, my mac says "a valid dvd drive was not found." How can I play the movie????
Good day..!!Maybe your using cd disk that why ur external wont accept it.,or maybe there was a error on your cd.thanks
Aug 17, 2011 | Samsung External Slim DVD-W USB Compatible...
I can't store movies,photos or videos in my external hard drive
I returned the product to the store and got my money back.
I will never buy a WD product again.
Apr 11, 2009 | Western Digital My Book Essential Edition...
Samsung HT-Z310 "Disc Error" Message....won't recognize disc
Turn off the power and hold the STOP ( ) button on the remote control for longer than 5 seconds (reset function). It fixed my Samsung Home Theature. Samsung has online chat to help too!!!
Oct 06, 2008 | Samsung HT-Z310T Theater System
Showing "Disc Error" While playing DVD's
the disc tray is not leveled properly, i had the same problem too and samsung repair centre just adjusted the tray.
Apr 29, 2007 | Samsung HT-DS100 System
Televison & Video Logo
2,584 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
