SOURCE: SAMSUNG SGH A887,HAS NO SOUND,HAVE CHECKED ALL THE
If you have checked all the settings and confirm that the problem is not with the phone's software, the it is probably a hardware problem malfunction. The problem is with the speaker. There is a disconnection somewhere that joins the board to the speaker.
To confirm this, if you do not hear phone conversations as well, try engaging a conversation with an earpiece. If there is audio, then the problem is most probably the phone's speaker, which might either needs to be properly reconnected or changed.
Hope this helps?
Method 1:
1 - Switch ON your Samsung SGH-A887 Solstice with a NOT ACCEPTED SIM Card.
2 - Samsung SGH-A887 Solstice will ask for "Password".
3 - Enter the Unlock Code.
OR (if the Samsung SGH-A887 Solstice shows "Insert Correct SIM Card")
Method 2:
2 - Don't bother about what's being displayed on your Samsung SGH-A887 Solstice .
3 - Compose : #0111*CODE#.
NOT ACCEPTED: We mean, to use a sim card from a network other than the network your Samsung SGH-A887 Solstice is locked to.
CODE: Its the unique Unlock Code for your Samsung SGH-A887 Solstice .
If method 2 does not work, you can try method 2 again but this time without any SIM card on your Samsung SGH-A887 Solstice .
Each Samsung SGH-A887 Solstice mobile phone has an unique unlock code. You can buy the unique unlock code for your Samsung SGH-A887 Solstice mobile phone using the form above.
