Service mode shows 0 for motor not running. Board Output test shows strange 2 digit error code olc,(or o and combined lc )Rotary cycle selector button set to Super Wash when pressed does not toggle on and off but lights on for both on and off. When Rotary Cycle selector button moved to other cycles there are 3 beeps each time. Have to push off button Board Input Test shows OP for open and UL for unlocked. Have to push off button Diagnostic test shows 22 error. Have to push button off. I am senior (lady) with no experience. Can I do something else or call a neighbor to check component testing and electrical connections? Can I fix this myself or what do I tell service repairman so I know he is doing this right? Thank you
It looks like you have a bad door switch and is the easiest and cheapest thing to fix on the washer part number 8182634 and it's around 65 dollars.open the door unplug the washer,remove the spring and pull off the rubber boot enough to get at the door switch,remove the screws pull out the switch and unplug it,put it back together,put some soap on the spring so it will go back on easier.hope this helps,also in the washer there's a tech sheet with all the codes and tells you how to run in diagnostics
SOURCE: My Amana NFW7200TW washer goes
Hello & Welcome to FixYa
ND error in your washer
indicates no drain issue. To start with check the drain hose for any clogs and
try cleaning it, then check restriction in drain pump assembly or loose wire at
the pump. Please get back to me if you have any other questions.
Kevin
E3 Error: Machine control is attempting to drive the motor but is not seeing any tach response. Visual check shows motor is not moving. (Locked, Hall Sensor fault). Replace the hall sensor.
The "hall" sensor is an internal circuit of the motor. It "tells" the machine control board, what the motor is doing, it's similar to a tachometer on the dashboard of a car. In your case, you want to do the resistance checks on the wires of the CN9 and CN8 connectors at the main control board in the front of the washer (it's easier and more indicative). Unplug the CN9 connector from the control board(red, white and blue wires) testing the pins inside the wire harness connector: from pin#1 /blue to pin#2 /white you should read 3 ohms resistance from pin#1 blue to pin#3/red, you should read 3 ohms resistance. from pin#2/white to pin#3/red, you should read 3 ohms resaistance. That will tell us the motor windings are damaged or not. At the CN8 connector, unplug the connector from the control board and insert the meter probes into the end of the wire harness connector; pin#4/orange to all other pins in the connector should have infinite resistance. pin#3/blue to pin#1/pink should have 4.7 ohms resistance. If you have these resistances, the motor and wiring are OK and you'll need the control board. If the resistances are not within 10% of the ones listed, you'll need to check the wiring harnesses and connections from the control board to the motor, and replace the motor if all checks OK.
Here is a link to the motor.
Testimonial: "Richard was great in his help."
Problem is door won't shut on front load washer so I took the top off and put my hand in and tried to release the mechanism because
