Question about Braun IRT3020 Thermoscan Ear Thermometer
How do you change batterie in thermoscam ear meter
Posted by Larry Goggins on
Adam D
    Spread the Word:
    An expert who has shared 5 answers on their Facebook wall.
    New Friend:
  • 41 Answers
On the side with the screen about 3/4 of the way to the bottom should be a tiny hole put a pen in it and push down to release the lock and open
Posted on Nov 18, 2013
Change the battery in the hard case
Start by unscrewing the lense cap retaining ring. Pinch and remove the clip from the negative (-) spring on the battery. Remove battery and slide new one in. Reconnect wire connector in between spring on the negative side of the battery. Note: some lanterns have a v'd plastic ear on the back of the reflector so when you go to screw the reflector back on, align the v'd ear with the plastic bar inside the case under the handle and slide it together until you can screw the retainer ring on.
Feb 28, 2015 | Energizer Camping, Backpacking & Hiking
Sony mdr if520r
what OS, windows?
this is called blue tooth.
if the laptop has bluetooth option it will be in the device manager.
under networks.
many don't. Sony Asbuilt codes are complex.
if it is missing , add one, they cost $5 (yes a dongle ,do-hickey)
for fun run bluetooth radar, now you can see all bluetooth in home.
if not, its not a feature set of you laptop.
blue tooth is a simple wireless, for 10 to 100 meter rage,
class 2 is 10 meters, class 1 is 100 meters.
it's a radio/ transmitter.
Sep 04, 2013 | Audio Players & Recorders
Whats the difference between a sound meter and a loudness meter?
sound meters detect sound that are less detectable by the human ear such as noise pollution. loudness meters measure volume
Jan 28, 2013 | Measuring Tools & Sensors
How to fix my uniden president cb radio?////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////
Sub another mike, I have seen situations where the mike was the problem, if no change, check the RF output transistor usually heatsinked to the chassis.
Mar 13, 2012 | Radio Communications
How to change AAA battery in headphone. Can't see how to open it to get to battery slot.
I looked inside the ear cups and moved the fabric. All the searching finally turned up the battery compartment on the outside of the ear cup with the switch on it. After that, it was easy. I also found out that you could disconnect the cable. That was interesting, too.
Dec 26, 2009 | Bose QuietComfort 2 Consumer Headphones
How do i change the batteries on my ha-w500rf jvc headphones
Remove the ear pad on the Left ear which has the power switch on,
The remove the 4 screws, then there are two silver screws holding the outer cover in place, remove these and then tae the cover off.
You will see there are two AA Ni-Cd batteries inside these can be replaced ith any rechargable batteries you wish
Sep 09, 2009 | Audio Players & Recorders
Ricoh KR-5 light meter needle won't move, new batteries
About the only thing you can do is clean the batt. cover and contacts in batt holder. Make sure batts are good. No parts are avail. for this model. However this is a rugged camera and you can buy a hand held light meter inexpensive.
Oct 29, 2008 | Ricoh KR-5 SUPER II 35mm SLR Camera
Razr - no ear speaker sound
check for dust on the tip of speaker points.clean the points on circut board also .check speaker with multi meter if speaker damage,change it.
Jun 21, 2007 | Motorola Mobility RAZR V3
Braun IRT3020 Thermoscan Ear Thermometer Logo
223 people viewed this question
Top Braun Home Experts
john h
Tom Chichester
Are you a Braun Home Expert? Answer questions, earn points and help others
