Oil change
SOURCE: I have inherited a tacumseh vantage 55 lawn mower
Hello keithanthony:
>>To View a Breakdown of this Unit Go to this Site Addy, http://www.searspartsdirect.com/partsdirect/index.action?sid=PSHx20080114x00001 and Enter the Model Numbers and Click Search. From this Page you can View Diagrams and Parts Lists for you Equipment Using the "View Sub Components" Section Near the Bottom Left. You can Also Enter "Owners Manual" in the Search Box and it will Direct you to the Page you Require.
>>The Spark Plug for Most Tecumseh Engines is a RJ 8C and it is Gapped to .030in.
Please, Do Not Hesitate, If I Missed Something or you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
Good Luck
Respectfully
jbridger (John)
SOURCE: need instructions for reinstalling throttle
You have to take the carb and exaust intake off (they should be attached anyways) so you can turn the carb at the right angle to reinstall the cable.
SOURCE: tecumseh vantage 35 carburettor
Here's an exploded view: http://www.lawnmowerparts.co.uk/partfinder_pview.asp?pID=1739
There's a picture here of your carb on a qualcast mower: http://chat.allotment.org.uk/index.php?topic=58598.0;topicseen
I hope that helps
SOURCE: i changed oil, blade, spark
Hi Make sure the blade and shaft can easily be moved by hand. First, remove the spark plug wire from the plug. Reach under the mower and see if the blade will turn or if something is stuck between the blade and the mower. Also remember that you have to hold the safety bar when you are starting the mower or the engine won't turn. It is possible that the cable from the safety bar to the engine brake has come loose. Follow the cable from the safety bar to the engine and make sure it is working.Also check whether the line from the gas tank to the engine is crimped? Also check this link to troubleshoot your problem:- http://www.ehow.com/how_7363405_troubleshooting-push-mowers.html
SOURCE: what type of oil should i use for a mastercraft, Prism 4 tecumseh lawn mower
5w-30 will be fine
