Hotpoint WF430 Front Load Washer Logo
Question about Hotpoint WF430 Front Load Washer
Hotpoint WF430 fills and washes continuously, manually move programme dial to rinse and spin then works fine. Do we need a new timer?
Macine fills and washes continually. I can pause/cancel the cycle and move dial to rinse/spin manually to complete the cycle. Sometimes the machine starts to fill but stops and all lights flash. I stop and restart the machine then it is fine until I have to manually move to rinse/spin.
Posted by Karen Williams on
Anonymous
    New Friend:
I use to hhave to do that my was filter was blocked
Posted on Apr 08, 2013
5 Related Answers
douglas smith
  • 1462 Answers
SOURCE: stuck in wash cycle
check if heating by putting on as hot wash and feeling the door. if no heat, check continuity thro the heater - modern heaters have a non-resettable cut-out in them which can cause problems. no heat then no program advance
Posted on May 08, 2007
Anonymous
  • 209 Answers
SOURCE: washer will not spin
normally i would suggest changing motor carbons for hotpoint washers, but my experience is that the WMA motor armature is weaker than the carbons, normally if there is no connection fault a replacement motor is the answer 9 times out of 10, not a job for the amature
Posted on Sep 02, 2007
Anonymous
  • 619 Answers
SOURCE: Hotpoint Aquarius WD420 5+5Kg
The water level vacuum switch are not working , check hose might lose.
Posted on Jan 05, 2008
Anonymous
  • 10 Answers
SOURCE: wf340 hotpoint washer
it will be to do with the pressure switch it may be faulty, but more often than not there is a blockage in the pressure chamber which is located at the bottom of the outer drum, check the chamber and the tube that goes up to the pressure switch to see if they are blocked if they are clear of obstruction then test the pressure switch,to do this unclip the pressure switch from the side of the machine but dont take the wires off once off pull the tube off that goes down to the pressure chamber once off blow in to the nossle on the pressure switch, you should hear it click and then when you release it should click again, if it doet click twice then that is your problem, hope that helps.
Posted on Feb 22, 2008
Anonymous
  • 3 Answers
SOURCE: Hotpoint WD61 stops near start of wash cycle
Replace brushes on motor it is really easy to do. Take top off washer and you can get to motor quite easily. Mine running like a dream now. cost me £8
Posted on Nov 17, 2008
WASHER FILLS WITH WATER AND AGITATES FOREVER. I
Based on your discription you do need a new timer.
2helpful
Kenmore 300 washing machine does not leave rinse cycle
This sounds like a bad timer. If the machine is several years old, the timer could be in need of replacement.
If you are handy, you can replace this device yourself and you should be able to obtain the part from any local Sears parts store or from the internet.
If you are not familiar with this kind of work, it would be best to have a technician replace the timer.
Hotpoint wma76 stops and displays ON
Could be rinse water valve ..Faulty Solonoid coil
Dial won't move automatically
The dial is not a timer that moves through the prog, it is a selector switch, which selects the programme you require, and therefore does not move round
You need to check the filter re the spin prob.
Remove rear panel, remove large black hose from bottom of tub, remove filter, and clean.
Refit filter and hose.
Test for leaks
Plz rate my solution.
Thanks
Kenmore Elite Washer
seems the timer knob is old and need of replacement normally happens due to age as the timer switches inside the timer knob become old and sticky mostly unable to move so the timer isnt able to do much of its job
New Whirlpool washer model WTW5700SW rinse cycle doesn't worker properly. The water never fills the tub & continues to drain. You have to manually move the dial to the end of the rinse cycle to have...
Sounds like what you are describing is the timer on the dial is not activating the next cycle. Timers are usually the problem when the cycles do not complete there cycle
Hotpoint wf430
Had similar problem. Blocked filter and faulty pump, clean filter replaced pump approx £25. Took about 20 mins
2answers
Machine stops in Rinse & Spin Cycle & leaks water
Hotpoint WF430 Front Load Washer This video will show you how to find that leak on any front loading washing machine
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
And don't forget to like us on facebook
Asko w6221 front load washer stops after wash cycle
Do all of your cycles work when you turn them manually? If one cycle does not work when you turn the dial on it then it will be your timer (The dial assembly $100-up) If all your cycles work manually, then it could be your timer motor which is attached to your timer assembly. If you turn the dial pass the wash, on to the rinse, does the dial automaticly move (when finishng the rinse cycle)to the spin cycle? If so then your timer motor is ok. The only wires close to the bottom are the motor, but these should be high enough out of the way.
Washer doesn't stop
select a hot wash of some kind and check if the water heats. if not, problem could be heater or associated stat
Top Hotpoint Washing Machines Experts
vince
Paul Carew
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
