SOURCE: shop-vac i lost book
open the top of the vacuum. remove ONLY the filter element. There should be a ball about a two inch diameter inside the cage. It's purpose is to shut off the vacuum flow when water reaches a high in the canister.
SOURCE: Shop Vac 12 wet dry canister
http://geeksquad.fixya.com/ThreadView.aspx?prdid=19255&thid=245090
Posted by Fa Fa on Nov 05, 2007
I'm not certain I have all the parts to my Shop Vac. I have no instructions so I need help describing how it works and a picture of the main parts.
Thanks for any help. Julia Harris
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. I am supplying you with the contact for the Shop Vac Factory Service for owner’s manuals listed below: for the website and the customer service line, but make sure you include the Shop Vac Model # and the Serial # as well. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://shopvac.com/contact.asp Customer Service 570-326-0502 Phone #
Shop-Vac Corporation Customer Service 570-326-7185 Fax #
2323 Reach Road
P.O. Box 3307
Williamsport, PA 17701
Hours are: Monday thru Friday 8:00 am to 5:00 pm (EST)
SOURCE: Help!!! It won't start.
When you say you checked your extension cord, what do you mean by that? Were you able to ohm out the wires to determine that you didn't have an inline break anywhere? Just because you changed outlets to a known good outlet, doesn't rule out a problem with the cord, switch or motor itself. If you have access to an ohm meter, volt meter, continuity checker or even an inductive power sensor ( electritians use these all the time to find live power feeds) then you may be able to determine where the problem lies.. I did a cursory search for a wiring diagram for that particular model but was unable to locate one. Not having that information means I am only speculating what your problem could be. Is there a reset button or popout circuit breaker on that model that may have tripped? If so, reset it and try it again. If not then you may need to do some troubleshooting of the hardware itself. Not sure I've helped you at all but I tried.. Hope you can trace out the problem... Good luck..
SOURCE: Bought house. Inherited shop/vac. A bit old, but
If you are going to use the wet vac to remove water, be sure to remove the bag inside the canister first. Also, some wet vacs have an internal float that has to be installed, but that may not be the case with yours.
SOURCE: using shop vac 52722-90 for wet applications
yes, the foam filter is what you should use, also make sure you remove any bag, or paper filter, the water would make it fall apart.
