Faux men's rolex date just
An authentic Rolex will have a screw down back with
exactly 144 small teeth. You can only open a Rolex case with a special
Rolex tool (Key). We use the Bergeon hand wrench to open Rolex cases. Supplied with 6 Bergeon
grooved chucks(18.50, 20.20, 22.50, 26.50, 28.30 and 29.50 mm), these
are the same chuck used in the Bergeon 5700RO and will fit in the
Bergeon Bit Adpater for 5700-Z Case Opener our number FB-231.
Replacement chucks and replacement handle are available in case you
have a set that is missing a piece. As is the case with any fine mechanical instrument, special
tools are required in order to properly service and adjust a precision
instrument such as a fine timepiece. If you are not experienced, it is better to leave this to a Certified Rolex tech. If you do feel you want to proceed, this tool will set you back about $140.00 or so. Just as the internal parts of the Rolex are exact, so is the watch case
that protect the valuable watch movement. These tools are used to open
the Rolex case without causing expensive damage. You can call Bob Frei at 510-832-0355 ext. 2 from 11 AM to 5 PM Pacific Time Zone, to order one if you wish, or several other sellers of these fine tools can be found by doing a little research on the net. Hope this has helped you.
