Question about Kenmore 5553 / 655532 / 55534 / 55539 Side by Side Refrigerator
How do you tighten the handle on the refrigerator side on my model #106.55522400? The bottom attachment is starting to loosen. If the inside of the door needs to be removed how do get it ofri
SOURCE: How do I tighten the refridgerator door handle on a Kenmore Side-by-Side Model: 106.57026600.
Service:
http://mrappliance2.reachlocal.net/land/
http://www.sears.com/sr/service_order/so_productinfo.jsp
DIY repear and diagnosic help:
http://www.acmehowto.com/howto/appliance/freezer/freezer.php
http://www.repairclinic.com/0047_3.asp
http://www.fridgedoctor.com/
Posted on Nov 12, 2007
SOURCE: Replacing water line in freezer side door
Yes as I stated on other posts, go to an appliance shop and get a threaded connector. Mine cost about $7 and i had to do some minor adjustment cutting to the plastic guard at the bottom of fridge/freezer...so the new piece would not put too much pressure on the line. The white coupling connector on the line u will see has a red and blue washer conected on eitrher side of water line. To disconnect line ..just push in on top of washer and pull line. Cut the torn lines so u at least have a line that is clean and mostly straight, but dont cut TOO MUCH!! just the bare edge, about 1/8 " inch. Use some needle nose pliers ,real small ones.. to pull the line from bottom of door and apply connector. Put lines back on and do faceplate and check for leaks. Good luck!!
Posted on Apr 04, 2009
SOURCE: Replacing the Ice dispenser motor on Kenmore elite refrigerator?
There is a small door under neath ice maker shelf (literally) w/ 2 small screws that keep it in place,or a button that can release ice maker on the rt. side of machine. Good luck!!
SOURCE: I need to take the handles off on my kenmore side
Try sliding them upwards ( the top ones ) , downwards ( for the bottom ones ) , as far as they will slide , then remove .
Posted on Nov 13, 2009
SOURCE: Ice maker leak in GE refrig.
when the refrig.goes through a defrost cycle the water from the melted ice is supposed to go out a drainline to a pan inthe back.most likely the drain has plugged up and needs cleaning.remoe shelving andtake back panel off drain hole is located below coils,be carefull of coils ,delicate
Posted on Jan 22, 2010
Testimonial: "Thank you, drain is clogged. Problem solved."
MFI2568AEW User Instructions If you do not have the free Adobe Acrobat Reader click here=> Adobe Reader X (10.1.1) first. Once you scroll down to page 7 in the PDF you can see the set screws that are hiding in a small opening under each side of handle. Below you can also click on the Maytag Logo and it will take you to the page that ask for model number. If you have questions after reading the instructions in your Maytag User Manual please let me know HERE, Thanks Sea Breeze
If helpful please rate my solution. Thank You
Manuals
