Brookstone LEGO Ninjago Kai Mini-figure Clock Logo
A
Anonymous Posted on Apr 06, 2013
Turn off military time
Time is displayed in military time. How do we set it for normal time? Thanks
jamie b
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Sep 30, 2013
jamie b
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
1952
Points
This baffled me for a bit...Finally I just took the batteries out, then put them right back in and it was no longer on military time.
How can I change Alexa on my Amazon Echo show to 24 hour time.
Question edited for clarity and toss in some CAPS.
Military Time is 24 hour Time, 00:00 to 23:99! It sounds like actually want 12 hour time, 12 hours of A.M. and 12 hours of P.M.
You just ask :>D
Say "Change to 24-Hour clock" or use the Alexa app.
  1. Open the Alexa app .
  2. Select Devices .
  3. Go to Echo & Alexa, or to All Devices.
  4. Select your Echo Dot with clock device. This opens device settings.
  5. Under General, select LED Display.
  6. Turn 24-Hour Clock on or off.
Change the Time Format on Your Echo Dot with clock
My father in law has an old Casio model 548 wrist watch. It's stuck in military time and he wants to reset the time to a 12 hour option and move into daylight savings time. Can you help?
from the user manual press the button closest to the seconds display on watch . bottom right button in normal time display to switch between am / pm time or 24 hundred military time.
http://mygshock.com/casio-manual/548/
enlarge the internet browser display to read which button to press to change the time or date.
press button B top left button to go into change mode
press button C bottom left button to move to seconds or minutes or hours .
press button A bottom right button to advance the time
press button b top left button to go back to normal time display
1helpful
How do you get the time from military to normal? and how do yo set the date and time?
  1. Press the "MODE" button---usually on the lower left side of the watch, but sometimes on the right center side---to cycle through to the time display.
  2. Press and hold the "SET" button---usually on the right lower side of the watch---until the seconds flash.
  3. Press "MODE" repeatedly to cycle through the displays that flash: from hours to minutes to month to date and day. At the end of the cycle is the hour display option. Make this option flash.
  4. Press the "SPLIT/RESET" button below the face of the watch to change the hour display option to "24-hour display." This is the same as military time. If there is a "NEXT" button on the upper-right side of the watch, use this to advance to the 24-hour option instead of using the "SPLIT/RESET" button. You may need to press a "START/SPLIT" button instead a "SPLIT/RESET" button to cycle between 12- and 24-hour display. The "START/SPLIT" button could be located below the watch face or on the upper-right side of the watch, depending on the model.
  5. Press the "SET" button again. You are now done. All PM hours should be displaying hours between 12 and 23.
Sep 19, 2010 • Watches
1helpful
Time is on military time. want to switch to
If you have the manual then it should explain how to change from "24" to "12" display.
If you haven't got the manual then some experimenting my find the solution to your problem. One of the buttons should cycle through the settings menu and in there should be an option to set the display.
7helpful
How do i get my athletic watch off of military time? It's a water resistant watch up to 165 ft. model # aw60447w
military time:
1. When setting the time on your watch, IF you watch can change to Military time(and most can)
2. when you are adjusting the hours go through a full 24 hour cycle. You'll notice that the 2nd time through it is on military time.. 3rd time through back to 12 hour day AM/PM cycle .. 4th time back to Military.
So you can do this as many times as it takes to get to the right time ..
In 24 hour time you will see an "H" displayed where you normally see and "A" for AM and "P" for pm.
Sep 23, 2009 • Watches
13helpful
4answers
Athletic Works Watch
With time displayed:
Press lower right, then upper left.
30helpful
3answers
How do I get my Timex WR50M watch out of the 24 hour (military) time and back to a 12 hour clock?
Hold down the adjust button bottom right then press the mode button top left you will notice the a or p that stands for am/pm will disappear & reappear. If you have an a or p on your display then you are out of military time.
6helpful
3answers
Set watch
I have a G Shock DW-004 made in 1997. I had this same problem, and I tried everything to change TO military time and back to standard time. I just read the bit to try and was about to do it. I pressed the top left button to get the time to flash, and hit the light button by accident (the one with the big G on it) and VIOLA! It changed to military time. So in my model, anyway, the G light button (under the display on the edge of the watch body) changed the time to military from standard and back again, when the time is flashing.
Feb 21, 2008 • Watches
Clock
when you are in t1 mode. All you have to do is press the 10 lap button- black bar at bottom of time display.
Top Brookstone Watches Experts
john h
ADMIN Eric
ADMIN Eric
ADMIN Andrew
ADMIN Andrew
Are you a Brookstone Watch Expert? Answer questions, earn points and help others
