Question about A.O. Smith SQ1102 Pool Pump Motor
Pool pump shuts off due to overheating - A.O. Smith SQ1102 Pool Pump Motor
I have a hayward 1.5hp pool pump that overheats and cuts off what is causing this?
motor is overheating the thermo is shutting it off for safety need a new motor or pump sometimes the whole pump is cheaper than fixing the old one
Jun 02, 2014 | Hayward Pool & Spa
Pump runs for about 3min and shuts off
It sounds like it is overheating. There is a thermal switch that shuts the motor off if it gets too hot. This may be because the motor is pulling too many amps due to a bad winding or the bearings are starting to seize. The best solution is to replace the motor.
Jan 11, 2013 | Hayward Pool Products Hayward Northstar...
Overheating
YOU MIGHT HAVE SET THE VOLTAGE WRONG.. IS THE MAIN BREAKER WIDE OR NARROW ? IF THE BREAKER THAT RUNS THIS PUMP MOTOR IS NARROW YOU NEED TO SET THE MOTOR FOR LOW VOLTAGE 115V ON THE MOTOR LABEL THERE IS A DIAGRAM ON HOW TO SET IT.. YOU NEED TO GIVE MORE INFO LIKE PUMP MANUFACTURE, TYPE AND MOTOR SIZE HP AND SF SERVICE FACTOR..WELCOME TO MY WORLD !
.JAY THE POOL PUMP MOTOR REPAIR GUY IN LONGWOOD FLORIDA.. REMEMBER TO VOTE FOR YOUR FAVORITE FIXYA GUY
May 06, 2012 | Pool & Spa
Live in florida - pool pump goes off for a half hour and then turns back on and then operates normally for a while. it then repeats the same eequence. is this due to overheating
it does sound like overheating. runs for a while, trips the high limit, then cools and restarts. this could be a supply power problem, under sized wiring, or loose or damaged terminals associated with the wiring.
Aug 13, 2011 | Hayward 1 12 Hp Super Swimming Pool Pump...
Pool motor keeps overheating and shuts off. Within seconds not minutes. It also seems to shut off just as it primes
CHECK THE VOLTAGE ON THE MOTOR BY CHECKING THE 2 LINES! SEE THAT MOTOR IS SET ON THE RIGHT VOLTAGE, DO A AMP CHECK, MAKE SURE THE START SWITCH IS CENTERED, HAVE THE START CAP TESTED . OR BING IT TO YOUR LOCAL POOL PUMP REPAIR GUY WITH FREE TESTING... THAT WOULD BE ME ''
Jan 27, 2010 | Hayward 1.5hp Pool Pump Motor Motor A O...
A.O. Smith SQ1102 Pool Pump Motor Logo
49 people viewed this question
Top A.O. Smith Plumbing Experts
Bill Johnson
Tom Chichester
Are you an A.O. Smith Plumbing Expert? Answer questions, earn points and help others
