SOURCE: Neff U1661 main element doesn't heat up
Hi.
Yes ,it is the element.
You need to remove the panel at the rear of the oven, this will give you access to the element.
Good luck
SOURCE: Neff U1421 main oven trips the circuit breaker.
It might be that the breaker is overloaded and it's no longer supporting the load of all the appliances together.If you do not want to change your breaker you can still use your oven by switching off other appliances that is running while you are using the oven
SOURCE: Neff U1452 tripping electrics
Hi
sounds like you have a faulty new element. sometimes depending how long you supplier has had the element they get damp and when they get hot they go down to earth. if i was you i would take it back and get another one and try that. hope this helps you .
regards dan
SOURCE: Neff U1410 main oven trips the main RCD. Occurs
I have a u1421 with the same problem! I notice the fan doesnt run too well, sometimes it doesnt run at all, needs a prod to get it running. I suspect with no fan, that the element gets far too hot, and then starts to leak to earth, tripping the RCD. I'm gonna try buying a new fan motor - you should ckeck if your fan is running full speed OK.
SOURCE: Pyrolytic cleaning won't start. Neff B15P42.0 GB
you have to remove the shelf supports (left and right) as well as the shelves. The manual tells you about the shelves but not the supports. I only found out as someone wrote the answer on another website
