Question about GE WSM2480DWW Unitized Spacemaker Washer and Gas Dryer
Wash machine water issues
One thing I've noticed about the washing machine. I noticed that the detergent (Tide) wasn't washing off the clothes very well. I checked the water temp. when it was set to warm and noticed it ran ice cold! When I switched to hot, it came out at a drizzle. My temporary solution has been to go buy Tide for cold water but some stuff really needs to be washed in hot or even warm.
Posted by Jason Behr on
daniel hendrickson
    President:
  • GE Master
  • 1,922 Answers
Pull the hot water hose off at the faucet and machine and check for blockage in the hot water hose,clean or replace the hose sediment screens,then hook back up to water faucet and flush hose with hot water,then check water valve on machine for a screen and clean it as well before reconnecting hot water hose
Posted on Apr 28, 2013
3 Related Answers
Master_Tech
Gary Davd
  • 770 Answers
SOURCE: Hot water continues to run after rinse, filling tub overflowing
sounds like you are right the water inlet solenoid on the hot side is sticking remove the hoses and clean th escreen out and the valve try agin with a fill on hot to see if it stops on a small load if not replace the water inlet valve
Posted on Mar 15, 2008
Anonymous
  • 5 Answers
SOURCE: thumping hitting front stops on wash cycle.
if it was not NEW and under warranty, you bet i would ask for your paid service in heartbeat.
the repairman is arriving finally tonight.i will update what he finds.
Posted on Apr 06, 2009
canbruce75
Bruce Canfield
  • 1776 Answers
SOURCE: Washer Fills HOT WATER ONLY
If you checked the screens at the water inlet valve and they were not clogged, then you probably have a defective water inlet valve and will have to replace it. Hope this helped.
Posted on Jul 19, 2009
My wash water smells bad. I leave the lid open between loads. When I do a wash it smells really bad.
After extended use, your washing machine can develop odors from the water, soap, residue, etc. The easiest and first thing to try is washing machine cleaner. You add this to the washer and then run a wash cycle. The product comes with instructions. Depending on the condition of your washer, you may have to run the cleaner through more than once.
You can usually purchase a washing machine cleaning product form stores that carry laundry detergent.
Here is a link to a product that you can try::
http://tide.com/en-us/shop/special-needs/additives/tide-washing-machine-cleaner
Here is a link for cleaning of a washing machine:
http://www.goodhousekeeping.com/institute/a23727/how-to-clean-a-washing-machine/
Aug 29, 2015 | Speed Queen 3.3 Cu.Ft. Heavy Duty Top Load...
Our Model WM2487H*M detergent box fills with water as the washer is working. We are using Tide pods in the drum.
The detergent dispenser is flushed with water during the wash cycle to remove residue. The flushing occurs automatically regardless of the type of detergent used, liquid, powder, or pods.
Jan 19, 2015 | LG Washing Machines
Maytag neptune frontloading washer overflow
If you cannot clear the line, you will need to replace it. Here is the line to order.
Nov 22, 2012 | Washing Machines
Excess detergent light comes on for every wash
Hi. I have had the same problem. I've taken off the top (2 screws on the sides of the top, under little caps) & I noticed that a sound deadening felt pad had come unstuck from the back of the machine and was being chewed up by the belt - this could be stopping the spin & causing imbalance, hence the excess detergent light coming on. I removed the pad completely and tested it. It now spins beautifully! However the detergent light still came on so I removed the soap dispenser unit completely (not the tray, the entire assembly which lets the water in and mixes the soap powder) and all the adjoining pipes which were completely blocked. I couldn't get the long one off going right down to the bottom but I squeezed it in an upwards motion like milking a cow (!) and got loads of grunge out. Hopefully that's fixed it.
Aug 08, 2012 | Washing Machines
I have a neptune front loader, after the wash cycle is complete the clothes smell like they have not even been wash with a **** moldy smell. I use Tide HE as directed but they still smell like i...
Hello, Thank You for using FixYa. I will be helping you today.Try 2 cups of white vinegar on a heavy duty cycle with hot water.Pour it in the detergent dispenser after it starts to fill. Also the affresh tablets work good i would use 3 tablets at one time if your unit is as bad as you say.
Thank You and please rate my answer if it was helpful..
Jun 17, 2011 | Maytag Neptune MAH5500B Front Load Washer
Lots of Dishwasher Issues- I have a Bosch dishwasher that is approximately 1 year old. For the first 6-9 months it cleaned perfect. It would wash everything off the dishes and leave them sparkling clean...
Do you have hard water? Many states have passed laws that outlawed phosphate as an ingredient in dishwasher detergent. If you have hard water, the detergents don't work very well anymore. The residue is probably hard water deposits (calcium and magnesium). Not harmful but it looks awful on your dishes. There are some new products that were designed to solve this exact problem. They are inexpensive and effective. Can't say the name or I'll get banned (again). Internet search will uncover it.
May 07, 2011 | Bosch 24 in. SHU43 Built-in Dishwasher
Even though I keep the door open when not in use it smells when actually in the wash cycle. How can we fix this as it is embarrassing.........
Hi and welcome to FixYa. I am Kelly. The yellow line is usually a resul of iron particulate in the water the machine uses. There are a few thing you can try to clean the machine.
You will not find this one in any manual.
Put one cup of bleach and 1/4 th cup "dishwashing powder" straight into the tub and run an empty or "cleaning rags cycle" with HOT water. You can add the juice of a freshly squeezed lemon or use lemon concentrate also with that. You may initially have to do this for 2 to 3 cycles to get rid of the iron deposits. After that you should use one of the products below before returning to reugular wash cycles.
There are other producs out there that you should use per their directions once a month.
http://www.affresh.com/#/home
and http://www.tide.com/en-US/product/tide-washing-machine-cleaner.jspx
Also make sure you using HE washing machine detergents vs regular washing machine detergent. Here is just one example:
http://www.purex.com/detergents/ultra-purex-he
Thanks for choosing FixYa.
Kelly
Jul 08, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Soapy smell in clothes
You might need to wash your washing machine.
Most consumers think they are doing what is *normally* the right thing to do, which is to follow directions on the detergent label. In this rare case--those directions should be entirely disregarded.
Additionally--in many LG washers--the liquid dispenser cup (blue cup) has a "MAX" line on the white siphon cap.
This was a very big *faux pas* on LG's part--this "MAX" line has NOTHING to do with measuring detergent and should never be used as a guide for determining correct detergent amount.
The "MAX" line indicates how much liquid must be in the blue dispenser cup before it DISPENSES from the bottom of the cup.
This is a very,very frustrating mistake that gives owners much grief.
After three months of incorrect type of detergent or incorrect amount of the correct detergent used--musty odor begins to occur.
After more than two years--a significant amount of soap scum/curd has accumulated in the washer. Odor-causing bacteria flourishes on this build-up.
It is imperative to remove this slimy residue. Tide sells a product called "TIDE WASHING MACHINE CLEANER" which is very effective if used the proper way:
Once a tub has become heavily contaminated--normal methods of performing a TUB CLEAN cycle won't "cut it".
Add the entire packet of "TIDE WASHING MACHINE CLEANER" directly into the tub (no laundry) and close the door.
Press and hold: SPIN SPEED & SOIL LEVEL buttons--then press POWER button.
Wait for door to lock.
Press the START button (6) times--this will fill the tub with hot water to the maximum setting when it stops filling.
Press the START button two more times--this will enable the tub to tumble.
After 3 hours--turn "off" the washer.
Turn the washer back "on".
Select the shortest wash cycle (usually "quick wash") and press "START". This will rinse out the tub.
This method of "TUB CLEAN" is *not* from a service manual but has been the best method for cleaning out LG washers more than a year into incorrect detergent usage.
After this--use the correct amount of "HE" detergent & perform a "TUB CLEAN" cycle every (4) months using the *tub clean* option on the control panel.
Got that? LOL
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jun 13, 2010 | LG WM2487H Front Load Washer
LG Fuzzy Logic 6.5 Kg WF-F733PC washing machine not spinning
hi...I have an LG Fuzzy Logic 6.5 Kg WF-F733PC washing machine & it's stop when 3-4 second start washing, wash and spin led appear also the buzzer bip contibuosly...any ideas?it's software problem....need advice
Apr 16, 2010 | Washing Machines
Bosch Nexxt 800 Washer Distugsting Smell
USING NON BIOLOGICAL DETERGENTS AND LOW TEMP WASHES WILL EVENTUALLY LEAVE GUNK IN DRUM AND AROUND DOOR SEAL TRY USING BIO DETERGENT HOTTER COTTON WASHES AND THE OCCASIONAL 90 DEGREE WASH
Aug 08, 2009 | Bosch Nexxt Premium WFMC6400UC Front Load...
GE WSM2480DWW Unitized Spacemaker Washer and Gas Dryer Logo
55 people viewed this question
Top GE Washing Machines Experts
Michael Thomas
Michael Thomas
Marvin
Marvin
Mike
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
