Gardner Bender #GSW-SK Door Switch Logo
ryan Posted on Apr 06, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Rewire a light box with four wires
Okay here's the deal. I went to pull down a pantry light fixture and when I did I found the box was housing 4 sets of wires (one for the light, one for the pantry door jamb switch, one for the can lights/fridge and one for the interior plugs of the pantry). IF I plug all the wires together (blacks & whites) the fuse pops. If I leave the white from the jamb switch everything works except the jamb switch. Is there a special way to wire jamb switches to lighting fixtures? also purchased a new jamb switch from Home Depot thinking it was defective (smelled like electrical fire). Here's a rough diagram of the interior of the box. A. Light B. Fridge C. Microwave D. Switch Please help. I have tried everything and am at wits end, and too stubborn to call an electrician.
Gene Haynes
Level 3:
  • Gardner Bender Master 5,391 Answers
  • Posted on Apr 07, 2013
Gene Haynes
Level 3:
Answers
5391
Questions
0
Helped
2604779
Points
14124
I can help... but cannot see your drawing.
Let's get started:
1) By code, the microwave? should be on dedicated circuit
2) You have 4 cables that enter the box.
3) Only 1 cable will be Hot and Neutral from breaker box. You must identify this cable first.
Here is drawing:
http://waterheatertimer.org/images/Pantry-door-switch-1000.jpg
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Testimonial: "Thanks, you totally saved my life and pocketbook. The drawing, was spot on and just what I needed. "
1 Related Answer
Anonymous
  • 520 Answers
  • Posted on Jun 15, 2009
SOURCE: Wiring Door jamb switch
I'm going to guide you on how to create what is known as a "switch leg".
1- run a 12-2 w/ground wire to the light fixture from new switch.
2- connect black wire "hot wire" to the shiny bronze tinted terminal on switch.
3- connect the white wire " neutral " to the silver connection on switch.
4- connect the naked copper wire " ground " to the ground terminal on switch
5- Disconnect the two white wires in the junction box from each other.
6- Connect the ground to ground in j-box
7- Connect the black to one of the whites in j-box
8- connect the white to the other white in j-box
9- wire nut and tape all connections
Oh and be sure that you turn off the breaker before you start. Hope this helps. Good luck.
2answers
Rewire a three-way switch that was wired knob and tube?
I can help u with this but will need to b able to walk u thru it,
2answers
Rewire lamp
It depends on the problem. Common problems such as bad sockets can be repaired by a handyman. Lamp sockets, switches and heat resistant fixture wire are readily available from big box stores, local hardware stores, etc. If the problem is related to the house wiring, you need to contact an electician.
How to replace dimmer switch
Hi Karen,
There are two types of dimmer switches - single pole (or S1) and three way (or S3). You can determine which type you have without even removing a screw. Here's how: How many switches can control the light fixture now? One or more than one? If you answered one, you need a single pole dimmer switch. If you answered 2 or more (it doesn't matter how many at this point), you need a three way dimmer. Ok, we're done with step one almost.. make sure that the one switch that controls the light has ON and OFF on the toggle handle. Likewise, none of the multi-switch arrangements that control a light should have ON or OFF on the toggle handle. None of the wide rocker or Decora style switches have ON or OFF on them.
Next, do the light switches that control the fixture only control an incandescent light? If the switch operates a light AND a fan - like a paddle fan fixture - you can't simply replace the switch with a dimmer. Dimmers are for use with a 120 volt incandescent lamps (tungsten, quartz, halogen, etc.). They are not designed to work on motors circuits - such as fans - nor are they designed to work for lights that have a "ballast" like neon or fluorescent types or a "transformer" like low voltage track lights, etc.. Check the bulb's voltage rating if unsure if a low voltage type or not. The only exception to the above that I am aware of would be for lamps that SPECIFICALLY state on the package that they can be used with a dimmer. You can find dimmable compact fluorescent lamps that will work, but as far as I know, there are no other types of lamps or motors for that matter that will work WITHOUT OVERHEATING or DANGER OF FIRE.
A retail package of dimmable CFLs.
That means, yes; if you install a dimmer on a motor, it will adjust the motor speed BUT, the motor WILL over heat and can easily start a fire. The same holds true for lamps that have a ballast. If it doesn't specifically state it is for use with a dimmer, don't try to use a dimmer to control it.
Check the wattage rating of the fixture. There is a sticker affixed to every fixture that indicates the maximum wattage of each lamp socket. Add these values together. Most fixtures are well under 600 watts. This 600 value is significant, as this is the base rating for dimmer switches. Nearly all unmarked dimmers are rated for 600W - but if you look closely, you should find this wattage rating along with the voltage rating on it somewhere. If your fixture is capable of more than 600W, you should select a dimmer that is rated to at least handle this wattage. The next higher wattage rating for most dimmers is 1000W, and costs about twice as much as the 600W dimmer. It only gets more expensive from here. Fortunately, not many residential applications need 1000W+ dimmers for the loads they will control. The need for 100W+ dimmers comes into play when there is a dimmer switch in the same box as the old switch. When converting a dimmer & switch to a dimmer and dimmer in the same box, the wattage rating is derated to disapate the heat created by the dimmers. Please, consult the chart below to see how to properly derate:
http://www.residential-landscape-lighting-design.com/lighting_dimmer_derating_ganging.htm
Ok, the preliminary work is complete. Shut off the power to the circuit. Remove the wall plate and remove the mounting screws that secure the switch from the switch box. Gently pull the switch out of the box. If it is a single pole switch, it will have two (2) terminals. If it has 3 or more terminals, (not counting the green ground screw) skip ahead to the three way section. If there are more than 2 wires connected to the switch (again, not counting the green ground screw), mark the wires so that you know which wire(s) go to which terminals. Use masking tape and a pen to write or colored tape to identify all wires that connect to the same terminal. Turn power back on. Test the all the wires for the presence of 120 volts. Once this is learned, shut the power off again. Test to make sure power is indeed off. Remove the wires from the switch terminal screws. Remove any bare or green ground wire from the green screw. The new dimmer should be connected so that the the "power" or "line" wire or terminal is connected to the wire(s) that you found to be powered in the previous step. If there was 2 or more powered wires that had the same identification or mark on them when testing - make sure all those wires get connected to this terminal of the dimmer. Connect the remaining wire(s) (that should also ALL have the same marking) to the remaining "load" or "light" wire or terminal of the dimmer. Make sure the wires that connect with a supplied wirenut have no exposed metal to short out. Check your work. Make sure none of the marked wires have been mixed with the other marked wires. Connect any bare or green ground wire to the green or bare wire of the dimmer or green screw on the dimmer. Gently fold the wires to the rear of the box or sides and insert the dimmer. Secure to the box with screws and install the wall plate. Turn on power and test.
If you have a multi-switch or three way installation, it's a little more complicated. Firstly, only ONE dimmer is used in the circuit. Installing more than one dimmer will prevent the light from being made brighter than the current brightness setting of lowest switch. If there are 3 or more switches that control the light, two are three way types; and are the only ones that can be changed to a dimmer. The third, and subsequent switches in multi-switch installations are "four way switches". Dimmers are not made to replace them. Three way switches have 3 terminal screws and four way switches have four screws (not counting the green ground terminal screw). This is the only way to determine one from the other. Start by shutting off the power. Go to the switch that you would like to replace with the dimmer. Remove the wall plate and switch mounting screws. Gently pull the switch out of the switch box. Count the number screws on the switch body (do not count any green ground screw). If it has 3 screws, it's a 3 way. If it has four, its a four way and can not be changed to a dimmer. If it has 4 screws, resecure the switch into the switch box and reinstall the wall plate. You will need to find a three way switch that controls this light. If none of the other locations is not desirable, you can not install the dimmer. Otherwise, remove any bare or green wire from the green ground screw. Next, locate the dark colored screw. This is called the "common" or "shunt" screw. Sometimes it is painted black; and other times it is gold when all the non-ground screws are silver colored. In any case, it will be the "odd colored" screw. Mark the wire(s) that connect to this screw with a number "1". Mark the wire under one of the other screws (it doesn't matter which) with a "2"; and mark the wire under the remaining screw with a "3". The wires that are connected to these terminals and marked as number 2 & 3 are called "traveler wires". Traveler wires run between switches and common (or shunt) wires that connected to the terminal with the same name and marked as number 1 does one of two things: it either comes from the power source or it supplies power to the light fixture. Make sure each wire that was connected to the 3 way switch has a number on it, then remove all the wires from the switch terminals. You will connect your traveler wires numbered 2 & 3 to the dimmer's traveler wires or terminals (it does not matter which wire is connected to which terminal; and the common or shunt wire numbered 1 to the dimmer's common or shunt wire or terminal. Many dimmers use black as the common or shunt and red & white for travelers. You'll need to consult the wiring information that comes with the dimmer to find out the colors used for common or shunt and the traveler wires on your switch. Check your work. Make sure no exposed wire can short when it is powered up, later. Carefully fold the wires into the switch box. Insert the dimmer into and secure to the switch box. Reinstall the wall plate and turn power on & test.
I hope this helps & good luck! Please rate my replay.
We have 48" lithonia flouresent
even if there is power at the sockets, ballast may not have power to fire off the lamps, how old is this fixture, and you need to replace the ballast same as in fixture, if you replace ballast make diagram of wiring so you can rewire it like it was wired from store.
2answers
I'm re-wiring a light fixture in our kitchen - went to shut-off the breaker and found that none of the breaker switches shut-off that circuit? When I shut-off the main breaker,it shut-off the circuit?...
When you shut off the main breaker it should shut off the circuit. However every circuit should have a breaker. Bad wiring. Call an electrician let him take a look
How to wire this fan
The wiring on most paddle / ceiling fans id such:
White = Fan and Light neutral or "common"
Black = Fan line voltage or "hot"
Blue = Light line voltage or "hot"
Green = safety ground
If you are replacing an existing light fixture - be sure to replace the ceiling box with one designed for use with a fan - as per electrical code. If the existing box had only 2 wires (or 3 counting the ground) that connected to the old light fixture and it was controlled from a wall switch, the wiring would be fixture white to ceiling white, fixture black and fixture blue to ceiling black (or red) and fixture green to ceiling bare ground or connected to the metal box. This would power both the fan and light whenever the wall switch was on and the pull chains for each were also on. This is also the preferred wiring for replacement of a pull chain type light fixture (no wall switch present).
If there are other wires in the box that previously were not connected to the old light fixture, using a meter or tester - determine if there is constant power between the ceiling white wire and any of the these other wires (test with the wall switch on and off to be sure). If you do have constant power available, you might consider using the wall switch to control only the light, and using the pull chain to operate the fan (or vice-versa). Simply connect the black (for fan) or the blue (for light) to the "constant power on" wire and that part of the fixture will work by pull chain only - regardless of the wall switch position. If the fan can be shut off by the wall switch, it is very important that the wall switch remain a toggle (or on / off switch), do NOT replace with a dimmer type switch.
If you'd prefer to operate the fan and light completely independently of each other - you can purchase a 3rd party fan & light remote control device for between $30 - $50.
I hope this helps and good luck! Please rate my reply. Thanks!
We have 2 identical fans in 2 different bedrooms. I had an aircompressor going and my daughter was running a blow dryer and it blew the breaker. Now both fans don't run, but the lights work. ?? the black...
Do me a favor, prior to reading on any further; did you try pulling (or turning) on the fan chain? As simple as this sounds, I've experienced this before. And I'd rather you try the simple solution first, before opening up the fixture. Okay, if that didn't work - the first TURN OFF the light switch or circuit breaker before working on these fixture's. If you're not well schooled in doing electrical work, I'd advise turning the circuit breaker off along with the wall switch. Now, when you open up your fixture, the black wire should be hooked up to the fan motor(s) lead wire; and the blue wire to your light(s) lead wire. Now, if both your fan and light were working before, then the wires at the fixture (black/motor and blue/light) were wired together. If so, then it could've blown both motor(s)? But I don't believe it did. Now that you've checked everything out, and your ready to turn the fixture back on. Keep the wall switch in the off position. Then go turn on your circuit breaker. If everything holds, then turn the wall switch on. It's done in this manner for safety reason's. Try this, and then let me know how it went. You should be good to go. Good Luck, and feel free to contact me again if you have any problems. Jim
I have a live 2-wire line that used to be connected to a light with a switch built into the light fixture. I removed the fixture and put wire nuts on the live wire. What I'm trying to do is to wire the 2...
As I understand it you have a live circuit going to a light fixture that had a switch built into it. You have removed the fixture and now you want to run this wire to another location and install a switch in the circuit.
You will be extinding these two wires (white and black + ground) to the new location. No problem ... Somewhere between where you start and where you finish, you will break the black wire and install a single pole switch. All connecctions must happen inside a electrical box.
So, install the new wire in the box where you will start your extension. Run to the new switch box. You dont even have to cut the white wire. You will wrap the green or ground around the ground screw on the switch, Cut the black wire . put one end under one side screw, put the other end under the other side screw. From this box run your wire to the next box where you will install your fixture.
If you are using metal boxes, they must be grounded to the circuit. You can use pig tails for this, Best deal is to use plastic boxes that dont require grounding.
I hope this answers your question
I have an outside spot light with a motion detector controlled by an inside switch. I want to change outside fixture & install dimmer switch in place of wall switch. I removed outside fixture. There...
First, let me say that if you're not entirely comfortable doing high voltage electrical work, you might want to call an electrician. It's not impossible for you to get hurt or killed or burn down your house. At least be sure to turn of the circuit breaker while you're working on it.
The blacks and whites twisted together are passing through power to other parts of your premises and are always on, so be sure to keep them twisted together. The red is the one that will take power from your light switch and send it to your light fixture.
At the fixture, connect the white to white and red to black, the same as before. At the light switch, connect the black to one side of the switch and the red to the other. When you turn on the switch, it will permit power from the black to travel down the red to the fixture, and from the fixture, the circuit will be completed through the white.
3helpful
Top Gardner Bender Electrical Supplies Experts
Sean Wright
Sean Wright
john h
Are you a Gardner Bender Electrical Supply Expert? Answer questions, earn points and help others
