Casio DB360G-9A 30 Pages Telememo Watch Logo
Posted on Apr 06, 2013
Adjust time onwatch - Casio DB360G-9A 30 Pages Telememo Watch
1helpful
How to make my Casio watch band smaller ?
To adjust the dual time on your Tommy Hilfiger watch model 1791709, follow these steps:
  1. Press the "Mode" button to enter the dual time mode. The dual time mode is indicated by the small "D" at the top of the display.
  2. Hold down the "Adjust" button for a few seconds until the hours digit starts flashing.
  3. Press the "Adjust" button repeatedly to adjust the hours of the second time zone.
  4. Press the "Mode" button to move to the minutes digit, which will start flashing.
  5. Press the "Adjust" button repeatedly to adjust the minutes of the second time zone.
Does anyone know how to adjust dual time. Cant seem to adjust the second time..Tommy Hilfiger 1791709
To adjust the dual time on a Tommy Hilfiger 1791709 watch, you will need to follow these steps:
  1. Locate the crown (knob) on the side of the watch.
  2. Pull the crown out to the second position. You should feel a slight resistance as you do this.
  3. Turn the crown clockwise or counterclockwise to adjust the time on the second time zone. The time on the main display will not change.
  4. When you have set the correct time, push the crown back in to the original position.
It is important to refer to the user manual for your specific watch model for detailed instructions on how to adjust the dual time feature. If you are unable to adjust the dual time on your watch, it is recommended to have it serviced by a professional watch repair technician.
1helpful
HOW TO SET NAVIFORCE WATCH DIGITAL TIME
TIME AND DATE
1. Press and hold MODE until HOURS digits flash (you'll be in Alarm Mode) Press MODE again to enter TIME mode, SECONDS digits will flash.
2. Press ADJUST to set SECONDS to zero.
3. Press START/STOP to select MINUTES.
4. Press ADJUST to change.
5. Repeat to set HOURS, MONTH, DAYS, and DAY of WEEK. Go through 12 hours to set AM or PM.
6. Press MODE when done.
7. To display DATE from Time display , press START/STOP.
8. With DATE displayed press and hold START/STOP, then press ADJUST to change display between DATE-MONTH and MONTH-DATE.
9. With TIME displayed, press and hold ADJUST, then press MODE to switch between 12-and 24-hour format.
ALARM AND HOURLY CHIME
1. Press and hold MODE until HOURS digits, DAY, and A or P (for AM or PM) flash.
2. Press ADJUST to change HOURS digits. Go through 12 hours for AM or PM.
4. Press ADJUST to change.. Press MODE when done.
5. Press and hold ADJUST, then press START/STOP to turn chime on/off. Press START/STOP again to turn alarm on /off. Release START/STOP when done.
CHRONOGRAPH
1. Chronograph will count up to 24 hours. Lap times are not stored. After 40 minutes chrono display changes from seconds to minutes.
2. With time displayed, press MODE to select Chrono Mode.
3. Press START/STOP to start.
4. Press ADJUST to view lap time. Press again to sesume lap timing.
5. Press START/STOP to stop timing . Press ADJUST to reset chrono to zero.
6. Repeat for successive laps.
Dec 16, 2018 • Watches
1helpful
Clock is 2 hours ahead of actual cst time
If you have an atomic clock/watch that is not showing the right time, you could have one or two separate problems. First, the clock may not be set for the correct time zone. Second, the clock may have a manual switch to adjust the time for daylight savings time. Each of these problems can make your clock display the incorrect hour of the time, especially after you change the batteries and your clock "forgets" some or all of its prior settings.
Check the back of your clock to see if there is a button or switch to set the correct time zone. If your clock appears to be set to your time zone, change the switch to another time zone and see whether the clock moves forward/backward to adjust. Once it has finished adjusting to the new time zone, adjust the clock back to your time zone to see whether it will now correctly reset to display the time.
I have seen atomic clocks that have manual adjustments for these settings as well as ones that adjust automatically other than the time zone. If you provide the manufacturer and model number of your clock, we should be able to provide more detailed instructions.
May 06, 2011 • Watches
1helpful
How to set time on timex 1440 sports watch
Welcome to FixYa!
Here's your request.
TIME AND DATE 1. Press and hold MODE until HOURS digits flash (you'll be in Alarm Mode) Press MODE again to enter TIME mode, SECONDS digits will flash. 2. Press ADJUST to set SECONDS to zero. 3. Press START/STOP to select MINUTES. 4. Press ADJUST to change. 5. Repeat to set HOURS, MONTH, DAYS, and DAY of WEEK. Go through 12 hours to set AM or PM. 6. Press MODE when done. 7. To display DATE from Time display , press START/STOP. 8. With DATE displayed press and hold START/STOP, then press ADJUST to change display between DATE-MONTH and MONTH-DATE. 9. With TIME displayed, press and hold ADJUST, then press MODE to switch between 12-and 24-hour format.
ALARM AND HOURLY CHIME 1. Press and hold MODE until HOURS digits, DAY, and A or P (for AM or PM) flash. 2. Press ADJUST to change HOURS digits. Go through 12 hours for AM or PM. 3. Press START/STOP to select MINUTES. 4. Press ADJUST to change.. Press MODE when done. 5. Press and hold ADJUST, then press START/STOP to turn chime on/off. Press START/STOP again to turn alarm on /off. Release START/STOP when done.
CHRONOGRAPH 1. Chronograph will count up to 24 hours. Lap times are not stored. After 40 minutes chrono display changes from seconds to minutes. 2. With time displayed, press MODE to select Chrono Mode. 3. Press START/STOP to start. 4. Press ADJUST to view lap time. Press again to sesume lap timing. 5. Press START/STOP to stop timing . Press ADJUST to reset chrono to zero. 6. Repeat for successive laps.
Thank you for using FixYa! Have a great day.
Jas247
I could not adjust Analog time of my G-300 Casio watch, however digital time adjusted, please guide me how to adjust analog time.
Pull the crown out. There may be a couple diferent stages (one step for time next step out for date etc)
Jan 25, 2011 • Watches
5helpful
How do I set the analog hands on my Casio G-300 Watch?
Go to Handset Mode,
Press Adjust, push D button onWatch,
you should also see Digital time also,
Push D button RIGHT >BOTTOM Button,
Set Time Accordingly. OCB
16helpful
3answers
Adjust time on casio telememo 30 watch
how to adjust time on casio telememo watch
Oct 26, 2008 • Watches
Kenneth cole reaction
I just dug my watch out after not wearing for a few years and had the same problem. There is an easy way to adust this watch's time and alarm, basically one way to enter both.
1) With the watch in the regular time display mode (doesn't matter if 12 hour or military time), depress and hold the lower left hand button (mode button). After a few seconds the watch appears to shift to alarm mode and it is blinking. This puts you into the mode for adjusting the alarm.
2) If you want to adjust time, date, etc rather than alarm time, after you have done step one, simply press that same lower left button again, and then it will put you into the time mode, but this time the time mode is blinking and you can adjust the various components (seconds, minutes, hours). You can only move minutes, hours, etc forward, no way to move backward. You will start off with the second display blinking, probably skip that unless you need to adjust seconds. Depress the upper right button to shift to the next option (minutes) and you will see the minute display blinking. Adjust the minutes by depressing the lower right button. When finished depress upper right button to move to next option (hours) depress the lower right button to move the minutes/hours/month/date forward as necessary, when you finish just press the lower left button again and it pulls you out of adjust mode and you are back in regular time viewing.
I had to post this because I've had this problem in the past and it killed me. Its kind of intuititve after you get into the adjusting mode by pressing the lower left button- remember, initially it will put you into adjust alarm mode, but press again and you will get into adjust time mode.
8helpful
Analog will not sync with digital
Dear I received gift of G-300 Casio watch but could not adjust the analog time where as digital time adjusted. Could you please help me to guide for adjsuting its Analog time.
Regards,
Tahir Khan
Feb 14, 2008 • Watches
Top Casio Watches Experts
k24674
Robert
ZJ Limited
ZJ Limited
Are you a Casio Watch Expert? Answer questions, earn points and help others
