Question about Staples TXC122ACC Cross-Cut Shredder; 12 Sheet
Parts manual for SPL-TXC122A
Need a drive gear on SPL-TXC122A
Posted by Rick Poindexter on
donyoungfami
I need a plastic gear for the Staples SPL-TXC122A Does anyone have one?
Posted on Sep 14, 2014
1 Related Answer
jeff_garmel
SOURCE: HI,I NEED PARTS FOR MY SHREDDER SPL-616X. GEAR
i have the gears - my shredder has broken plastic guides but the gears look fine. i'll mail them to you if you like. Jeff
Posted on Nov 20, 2010
Replacement gears spl-1506x
unless that shredder is heavy duty office and very expensive , it will be cheaper and easier to junk it and get a new one
mostly parts are non existent for shredders
Sep 23, 2018 | Staples Office Equipment & Supplies
Where can I get a spare key for Staples model spl-txc122a
Staples Paper Shredder Model SPLTXC122A
 Hey John,
Angela here. I have the same exact model Staples Paper shredder.spl txc122a. I have been looking for a bin because mine stopped working 3years ago because one of the grooves in the bin broke, that stopped it from working.
It is the best paper shredder I ever had and I refused to let go of it even after staples wouldn't fix it or even sell me another bin. Well here I am today searching all over the Internet AGAIN; looking for amother bin and was about to give up and found your post.
I have a key if you would like to purchase it for a small fee of $30 if you want the shredder as well for a backup I can sell it as well for $50 As I explained before the bin is no good so i'd only ship the shredder which is very heavy so the majority would go towards shipping.
I've had it! I'm cleaning house and giving up
Ang
Mar 13, 2018 | Cars & Trucks
I have a SPL-TXC122a shredder and I need the plastic drive gear Know where to get one?
I tried to get one for my machine but to no avail. So I fixed my gear myself. Go to your local hardware and buy a "Devcon" plastic welder. Not inexpensive.
You have a broken tooth on the plastic gear. Use a very small
drill bit the size of a big paper clip. drill three holes where the tooth broke off ( if part of the gear tooth is still there, file it down smooth.) Cut three pieces off a paper clip and insert them into the holes. Make them extend to below the gear and not to extend above the original tooth. Now you will make a tooth with the plastic
weld. Fill where the broken tooth was and let it set. Also fill where the paper clip extends below the tooth. This will give it more strength. Let it dry and harden. Now with a small file, file it to make it fit to the next tooth so it doesn't make a bump. " if you can before the mix dries, replace the gear and turn by hand the steel gears to make a smooth fit. Wipe any excess mix away. Good luck....
PS. mine is still working after three years....Hint do not try to shred
to many papers at one time. And once in a while put some 3 in one oil on a piece of paper in a sig sag motion and run it thru the machine. This will help to quiet the noise and oil the cutting blade.
Nov 04, 2014 | Office Equipment & Supplies
Lockout key replacement for paper shredder model# SPL-TXC122A
I am not sure what you mean by a LOCK OUT KEY but perhaps this link to the manufactures site might help.
www.fellowes.com/us/en/support/Pages/faqs.aspx Fellowes Support FAQs
Jul 13, 2014 | Staples SPL826X (CrossCut) Shredder
Spl-txc122a
The motor runs reverse even when in Auto mode, how do I fix it, and why did it happen
Mar 27, 2013 | Staples SPL1506X (CrossCut) Shredder
Drive gear for staples shredder Model# SPL-770M is worn
is it the drive gear or is it that the shreader is dull that makes the shreader sluggish?
Apr 04, 2009 | Fellowes Office Equipment & Supplies
Staples TXC122ACC Cross-Cut Shredder; 12 Sheet Logo
4,715 people viewed this question
Top Staples Office Equipment & Supplies Experts
gbob59
Marvin
Marvin
Vernon Taylor
Are you a Staples Office Equipment and Supply Expert? Answer questions, earn points and help others
