Kenmore 24032\24036 Top Load Washer Logo
Posted on Apr 06, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Kenmore ultra fabric care model 110 need manual
prem mathew
Level 3:
  • Kenmore Master 662 Answers
  • Posted on Apr 30, 2013
prem mathew
Kenmore Master
Level 3:
Answers
662
Questions
Helped
265267
Points
1748
5 Related Answers
JR JR
Johnny Ramirez
  • 116 Answers
  • Posted on Nov 30, 2008
SOURCE: I have a kenmore ultra
IS THERE A RATTLING NOISE WHEN U PUT ON SPIN CYCLE IF SO REPLACE / BROKEN COUPLER
onthejob5130
onthethejob1
  • 640 Answers
  • Posted on Jan 04, 2009
SOURCE: What is the capacity of a my washer.
4.2 thats about 26 pounds
Anonymous
  • 15935 Answers
  • Posted on Sep 14, 2010
SOURCE: win did the kenmore ultra fabric care 80 serles come out
It appears your Pressure Switch has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Anonymous
  • 15935 Answers
  • Posted on Sep 16, 2010
SOURCE: I have a kenmore ultra fabric care 2
It appears your timer/main controller/CCU has failed in this instance.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question!!!!!
Anonymous
  • 1937 Answers
  • Posted on Nov 05, 2010
SOURCE: My kenmore ultra fabric care
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.######) and you'll see a list of major sub-components with diagrams and parts.
Newer model Whirlpool / Kenmore washers use a Lid Switch as a safety device. Unless the switch senses that the lid on the washer is closed, the washer will neither agitate nor spin.
Older models only used the switch during the spin cycle.
Try to bypass the Lid Switch by removing the Console and jumping the two outermost pins on the switch.
This is a Whirlpool PDF on how these washers operate. It has a diagram on jumping the switch as well as a detailed section on how the transmission works.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
It also has a troubleshooting guide.
To bypass the switch, you only have to disconnect the power to the washer, tilt the console back, unplug the switch and using an short piece of insulated wire, jump the two outermost contacts on the connector coming from the console and plug the washer back in.
Following is a description of how to gain access to the console and how to remove the cabinet if necessary.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=131&osCsid=913ba652cd504fb162f87d892bcb427b
With the jumper in place, try to re-start the washer.
If it works, the Lid Switch is a relatively inexpensive part and only requires you to access the console and remove the cabinet.
1helpful
I have a kenmore ultra fabric care 90 series waher that won't agitate or spin. please help. model 110.92593410
please read the manual carefully, it contains all the infos & the solutions to problems you might confront. If not, please take it to specialst who can help
Dryer wont start kenmore ultra fabric care model # 110/87880800/78808
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Jan 04, 2011 • Dryers
2helpful
Kenmore dryer Ultra Fabric Care 90 series. No
If you have a gas dryer check out this tip...
If you have electric check out the tip for electric at the bottom of the gas tip...
http://www.fixya.com/support/r3866744-dryer_not_working_dryer_not_drying
heatman101
4helpful
1helpful
Need cu size of my broken washing machine.
it is a 3.0 cubic foot.
  • I would do some research before spending a lot of money on a front loader.
only thing i can think of without being there and able to test parts is your door catch could be faulty
Alexander
vince
