Using
a microphone with computer
To use any microphone with your
computer you will need to enable it in control panel. The following
instructions are for Windows XP but are broadly similar for Vista
and Win7
Click START, CONTROL PANEL, SOUNDS
& AUDIO DEVICES
Click VOICE
In Sounds & Audio Devices
Properties window locate SOUND PLAYBACK box. Click the VOLUME button. Make sure
that there is not a check-mark in the MUTE box against microphone in the list
of devices and that the volume slider is at the top of the scale.
Make sure the MUTE ALL box isn't
checked before closing the window.
Now click the VOLUME button in the
SOUND RECORDING BOX. Here SELECT microphone as an input source for recording
(as opposed to un-checking mute in the playback controls).
NOTE if your microphone
is not listed in the 2 sets of volume controls click OPTIONS, PROPERTIES
on the tool-bar and place a check against microphone in the list
entitled 'show the following volume controls' and then click OK. Same
applies for Internal mic.
That should be it.
To adjust audio volume generally.
Under VOLUME tab adjust Device Volume
as necessary. Also (under Loudpeaker Settings) click Speaker Volume and adjust
slider to suit.
You might put a check mark in the box
to show the volume control on the Task Bar so you can go straight to it to make
adjustments in the future.
Using
and Win7
& AUDIO DEVICES
Click VOICE
That should be it.
slider to suit.
Using
and Win7
& AUDIO DEVICES
Click VOICE
That should be it.
slider to suit.
Using
and Win7
& AUDIO DEVICES
Click VOICE
That should be it.
slider to suit.
Using
and Win7
& AUDIO DEVICES
Click VOICE
That should be it.
slider to suit.
Using
and Win7
& AUDIO DEVICES
Click VOICE
That should be it.
slider to suit.
If you still don't get enough volume then you may need a pre-amplifier to boost the signal
Using
and Win7
& AUDIO DEVICES
Click VOICE
That should be it.
slider to suit.
Using
and Win7
& AUDIO DEVICES
Click VOICE
That should be it.
slider to suit.
Using
and Win7
& AUDIO DEVICES
Click VOICE
That should be it.
slider to suit.
Using
and Win7
& AUDIO DEVICES
Click VOICE
In the Sounds & Audio Devices
Properties window locate the SOUND PLAYBACK box and click the VOLUME button.
Make sure that there is not a tick (check-mark) in the MUTE box against
microphone in the list of devices and that the volume slider is at the top of
the scale.
Also make sure that the MUTE ALL box
isn't checked before closing the window.
SOUND RECORDING BOX. Here you need to SELECT microphone as an input source for
recording (as opposed to un-checking mute in the playback
controls).
NOTE if microphone is not listed in the
2 sets of volume controls click OPTIONS, PROPERTIES on the tool-bar and
place a check against microphone in the list entitled
That should be it.
However - if you cannot get enough
volume on the microphone you may need to purchase a pre-amplifier to boost the
signal strength before input to the computer.
