Question about Motorola Mobility H730 Bluetooth Headset
H730 Bluetooth I can hear people but no one can hear me
I have disconnected from phone and reconnected but still have problem. I hear everything clear but no one hears me.
  • K_Oneal Apr 16, 2013
    Already tried that....mute is not on.
    Checked the mute several times
    New Friend:
    Problem Solver:
  • 17 Answers
You have the 'Mute' turned on. With the H730 turned on, and wearing it, press and hold both volume buttons until you hear a beep, or a voice prompt. Then try making a call. If that doesn't work, repeat the process. Good luck.
Posted on Apr 07, 2013
5 Suggested Answers
Anonymous
SOURCE: Can not hear on bluetooth
Greg
Heres what you do.You throw the damn thing against the wall and then dump it in the trash!!!!!
This things are pieces of shit and they need to be destroyed!!!!
Posted on Feb 08, 2008
otacon
Damen Wong
  • 1950 Answers
Did you check that you didn't by mistake activate mute? Also, check that there is nothing obstructing the microphone hole on the headset.
Posted on Jan 10, 2008
Anonymous
  • 73 Answers
SOURCE: Bluetooth H710 new..mic not working
Go in phone to setting then go to bluetooth and press it then select voice routing incoming hands-free
Posted on Aug 25, 2009
Anonymous
SOURCE: Motorola HS820 - cannot hear anything nor can others hear me
It turns out it was the Blackberry's problem, which could only be solved by a 're-boot' - take off the back of the Blackberry, pull out the battery for 10 seconds or so, and replace it. The BB will 'reset' and all was fine then.
Posted on Feb 17, 2010
Anonymous
  • 17 Answers
SOURCE: having problems with motorola h710 bluetooth
Check your Bluetooth visibility
It has to be set to ALL
Yours may be set to HIDDEN, which means they cannot "hear you"
I hope this help!
Posted on Apr 16, 2010
When trying to pair my H730 with my phone I get the message "can't communicate with Motorola H730".
Sometimes pairing is hard but your phone especially Bluetooth device to your phone cell phone to not recognize your Bluetooth device may not pay very well with some phones I recommend a universal Bluetooth earpiece has high capacity to go with any model carry your phone1 only get you one or two
Oct 09, 2016 | Motorola Mobility H730 Bluetooth Headset
H70 cant connect with my dell laptop it worked good yesterday maybe I removed something or changed setting
Disable and tenable Bluetooth. Clear past history. Put headset in pairing mode then use computer to search.
mark
motorola support
Aug 31, 2014 | Motorola Mobility H730 Bluetooth Headset
H730 i cant hear anything
Try unpairing the phone and the Bluetooth headset. Also ensure that you always have the boom on your headset open while trying to use it. The Boom is the on/off switch.
Mark
Motorola Support
Jul 23, 2014 | Motorola Mobility H730 Bluetooth Headset
How do I sync my phone with the H730?
Turn off H730,
1) have you ever paired the H730 to any other devices? if so make sure those devices are turned off.
2) Next make sure that your phone has bluetooth featured turned on.
3) Turn on the H730, if there is no devices that the H730 headset can pair to, it should go into descovery mode, the headset light should turn a steady blue, and you should hear "ready to pair"
4) At this point go to your phones bluetooth options and search for bluetooth devices. The H730 should show up
5) It then should ask for a password, 0000
6) after entering the passcode the H730 should say pairing complete
Make sure that it is fully charged, usually takes about an hour to charge completely.
Mar 11, 2014 | Motorola Mobility H700 Wireless Headset
Motorola h730 after factory reset will not stay paired after closing and opening again
Delete the pairing on the phone and then re-pair. Also ensure your headset is fully charged. It should autopair with your phone after a reset when you open boom if phone has bluetooth turned on and is in range.
Mark
Motorola Support
Feb 10, 2014 | Motorola Mobility H730 Bluetooth Headset
I have a plantronics bluetooth. I'm not sure of the model. After I talk on it sometimes the bluetooth will peep and seems to disconnect from my voyage phone but the bluetooth stays on. I hit the call...
Install Nokia Phoniex in your computer and attach handset.
1. detect device 2. click on device information and print it. you got answer
Jul 01, 2010 | Cell Phones
Motorola Mobility H730 Bluetooth Headset Logo
415 people viewed this question
Top Motorola Mobility Radio Communications Experts
Lawrence Oravetz
Dennis
Are you a Motorola Mobility Radio Communication Expert? Answer questions, earn points and help others
