You may download a copy of the manual from here.
SOURCE: Olympus FE 240 - downloading problems
Remove the Software
Restert the Computer
Plug camera in and turn on set it to the upload mode.
Windows will then fid it via the Camera/Scanner Wizard.
If there is still a problem
A cheap card reader will do the trick
SOURCE: Camera into a web-cam
If your camera has a video and audio output like many of these types of small digital cameras, you can get a video capture card for your computer. Install the software and drivers for the capture card. Then you feed the camera to the capture card using the proper connection cables. The MSM, Yahoo, and most of the other conferencing softwares should be able to see the capture card as a video and audio source.
For the camera, you will need the AC adabtor. The camera's internal batteries are going to run down very quickly when using the camera in the video mode.
You may find the video content very large in data bandwidth if you don't have the means to compress the audio and video. Using the full resolution without compression may cause some problems and large amounts of streaming bandwidth. If the other users are on dialup, or if you are on dialup, this will be a big problem.
My preference would be to get a good Webcam that can work on the USB port. There will be no bandwidth compression problems, and it was designed for this type of job.
Jerry G.
SOURCE: I need a manuel for an Olympus FE-310 Camera.
http://www.olympusamerica.com/files/FE-310_Instruction_Manual_EN.pdf
here u can download...
SOURCE: Need battery cover fo FE-240 Olympus Digital Camera
Unfortunately there are no parts that can be purchased directly by a consumer for this camera. The camera would need to be sent to an Olympus repair facility for service.
http://olympusamerica.com/cpg_section/cpg_servicerepair.asp
Olympus will charge a flat rate repair fee for this product if beyond the one year factory warranty or the warranty is voided. The cost is $83.85 plus your local sales tax. This covers parts and labor, factory cleaning and diagnostic check, 6 month warranty and the cost of shipping the product back to you is all included in that price.
SOURCE: I need to delete All
Hi ig_sandringh,
To delete all the photos from your camera, you can either connect it in mass storage mode and delete all the photos that you find in the relevant removable drive or you can select all the photos from the camera itself and delete them ,
I would recommend you to delete the images via your computer as it would help in better selection.
Hope this helps..:)
