Which graphics card can I use? I can't find one that is compatible and is supported with the needed driver.
SOURCE: video on an asus A8V-E deluxe motherboard
When you rightclick on MY COMPUTER then choose MANAGE, in the device manager, do you have another display controller appearing?
if so, then you only have to install the drivers you've got with your new card, then in DISPLAY from the control panel, you will have to go to the SETTINGS tab and lightly move the second diplay then it will ask you if you want to activate it.
if there is no other display controller in the DEVICE MANAGER you should try to reboot and access the bios in witch you will found an option for selecting the first display controller to be used.
so, choose PCI, and save, then reboot.
SOURCE: For ASUS A8V-MX Motherboard which graphics card should use
This Motherboard has onboard VGA, but if you want to upgrade the expansion slot is a AGP. so you will have to purchase a AGP VGA card. ATi or Nvidia would be good enough.
SOURCE: does ASUS P4P800 deluxe support high density memories
Here is a link to Asus' Qualified Vendor List of RAM modules for your motherboard. I do not see it mention high density RAM. You would need to search the specs on the modules recommended to be sure.
ASUS QVL
In case you don't have the manual, here is a link for it too:
ASUS P4P800 Deluxe Manual
Memory info begins on Page 2-10. Again, there is no mantion of HD modules.
SOURCE: Need list of compatible Graphics
Following graphics will work for you.
AGP 8X
ATI Raedon series video cards
NVIDIA geforce series cards.
Thanks
SOURCE: my motherboard is k8v-vm
Audio driver
You'll need to go to the Realtek website
Click The Downloads button at the top of the page.
Click the High Definition Audio Codecs (Software) link
Tick "I accept the above" then wait for the page to update then click Next.
You will now see a page of files available for download, at the top of this list is..
Vista, Windows7 Driver (32/64 bits) Driver only (ZIP file)R2.37 2009/11/20 38690k
Click on the first Go link for Site 1 and download the ZIP file.
Once complete, extract all the files from it and run the setup.exe file.
Run through the installation and it will ask you to reboot.
You now have sound !
Graphics drivers
As this motherboard was manufactured way before Windows 7 was released there may not be compatible Windows 7 VGA drivers for it.
If you go here there is a list of drivers or this board but none of them support Windows 7.
Try downloading the ASUS K8V VM Video driver for Windows XP, it may work.
