Question about MK Battery 24V 4AMP Scooter Battery Charger
I have just bought a used sterling sapphire 2 for my wife. We have to keep it in the garage which has no electricity supply. Can I buy a bit of kit that allows me to charge the battery in the house?
Posted by John Williams on
Rob Muncaster
    New Friend:
We have the same scooter and it is designed only to be charged through the socket on the console using the supplied 24 volt charger which monitors the charge very accurately. Although it has two 12 volt batteries which could theoretically be removed and charged with a 12 volt charger, I really wouldn't recommend it.
Is it not possible to take just the batteries and chassis part indoors to charge it as they're not very heavy?
Posted on Apr 29, 2013
Bill Boyd
    Top Expert:
  • MK Battery Master
  • 53,816 Answers
Go to a battery supply shop and they will be able to put you onto a good 24v trickle charger They may even sell them also.
Posted on Apr 06, 2013
How to remove washing machine from jayco sterling 2013
I PRESUME YOU WAN'T TO REMOVE A OLD WASHING MACHINE,
1. PULL OUT ELECTRICAL SUPPLY PLUG.
2.PULL MACHINE OUT A BIT TO GAIN ACCESS TO BEHIND MACHINE, SOME MACHINES HAVE COLD WATER SUPPLY PIPE ONLY BUT MOST HAVE HOT AND COLD SUPPLY PIPES.
THERE SHOULD BE A SHUT OFF SUPPLY VALVE AT THE SUPPLY SIDE OF THE TWO HOSES, CLOSE THEM BOTH THEN DISCONNECT HOSES, DRAIN HOSE SHOULD JUST LIFT OUT OF PIPE BEHIND MACHINE , NOTE ALL HOSES WILL LEAK SOME WATER ONTO FLOOR IF LAYED DOWN
A SACK TRUCK IS THE BEST WAY TO MOVE MACHINE
Nov 12, 2016 | Washing Machines
What fluid is used in mobility scooters electronic brake for sterling sapphire
There is no fluids in either brake on on these,there is two braking systems,both electronically operated .when stopping or slowing up power generated in motor is returned to the battery .this rapidly retards the motor dynamically braking the scooter,a fraction of a second after stopping the electric parking brake is applied by removing its 24volt supply,this is the click you hear when starting or after stopping the scooter.the only servicing reqd is to dust of the casing of the electromagnetic parking brake. do not dismantle it,or oil it.to test try to push scooter,if it moves easily when NOT in freewheel.replace it.
May 23, 2014 | Health & Beauty
Bought a sterling 75 c garage heater burner lights but then 24 v transformer burns out
I didn't find that model but did see a pretty standard wiring schematic for Sterling garage heaters in one installation manual. I'm sure they didn't change much. I did notice they use a 50va transformer, not 40 which is likely what is getting used now. Don't think that would fix it, just an idea. Put a 5 amp fuse inline on the red side of the secondary side of the transformer. This will protect it. I'm willing to bet the ignitor section on the low voltage common is wired wrong. Remove the tstat wires, buy a resettable fuse and install it first. Then get the fan running first. If there is a g terminal jump red to green. This is fan only, start simple, hope this helps
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
Jun 18, 2017 | Sterling RF75 Natural Gas Heater (75,000...
I need help to get a sterling sapphire ls user manual please can you help me to get one
contact Sunrise Medical @ (800) 333-4000
ask for tech support see if they can help you Hope this helps
May 07, 2011 | Electric Mobility Power Electric Scooter...
I have a Sterling heater in my garage - Model QVF 30. The thermocouple has apparently gone out because the pilot will not stay lit. Do you have a replacement thermocouple, or can you tell me who deals...
ACE hardware, Tractor Supply, H Depot or Lowez should have what you need. Bring the old one with you. You may have to purchase one a bit longer, just keep the extra coiled up out of the way.
Mar 02, 2011 | Sterling Heating & Cooling
Sterling sapphire 2 4wheel scooter
Larry,
Many scooters use a special charger that will not overcharge the batteries. Your best bet is to run a long extension cord to wherever you are safely storing you scooter and use the on-board charger. Be sure to charge your batteries often, since they last a lot longer if you do not run them down too far.
Oct 27, 2008 | Health & Beauty
MK Battery 24V 4AMP Scooter Battery Charger Logo
176 people viewed this question
Top MK Battery Health & Beauty Experts
ray gallant
Bill Boyd
Andrew Taylor
Andrew Taylor
Are you a MK Battery Health and Beauty Expert? Answer questions, earn points and help others
