Cooling System for BMW 318 ti Logo
Posted on Apr 06, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Free bmw 318i workshop manual
Leaking water from cooling system bmw 318i
Bill Boyd
Level 3:
Top Expert:
  • BMW Master 53,816 Answers
  • Posted on Jul 29, 2013
Bill Boyd
BMW Master
Level 3:
Top Expert:
Answers
53816
Questions
7
Helped
11950053
Points
172802
Have a pressure test done on the cooling system to determine the position of the leak and fix the problem
My 2000 bmw 318i doors and windows have locked themselves from the outside and will not open wilh the remote only the boot will unlock
I think you should go for repair manual first for your vehicle after that it will be easy for you to solve the problem. Check the link may be you will get something useful here
2002 BMW 318i Workshop Service Repair Manual
Hi my name is keith,i have a leaking water system on my bmw 318i 2002 model estate
This is most likely your water pump, if it is leaking in a sort of straight stream out when your vehicle is running it is the water pump.
2answers
Why bmw e46 318i heater not blowing hot air?
you low on rad fluid? Most common reason.
1helpful
Will a 1991 automatic BMW 318I driveshaft fit in a 1991 manual BMW 318I R
no the auto is shorter because the transmission is longer
1helpful
A red warning light comes on when I drive my BMW 318i dolphin.
Please refer to the owners manual for red light warning, it can be low oil pressure or hot engine or emissions system. If you don't have an owqners manual you can find used ones on eBay Motors.
2answers
Ownes manual for 1998 bmw 318i
BMW Owners manual. 1998 BMW 318i 4DR E36 BMW 318i CONV E36 BMW 318is 2DR E36 BMW 323i 4DR E36 BMW 323i CONV E36 BMW 323is 2DR E36 ... data.bmrparts.com/bmwparts/1610.html
have just checked this site out and the have a manual for yr bmw - hope this will help-
2helpful
2answers
I have a 1994 318i convertible. It continues to overheat. I have changed out the thermostat, The radiator has been checked at a shop and found good, I changed the waterpump also. The electric cooling fan...
It's possible that you have a bad head gasket. Have your cooling system pressure tested, see if it holds roughly 18lbs of pressure. Could also be air in system, did you bleed system when waterpump and thermostat were installed?
5helpful
4answers
1994 bmw 318i
Where is the water pump on 94 BMW 318, Is it behind the Fan or a seperate unit. is it easy to replace?
Top BMW Vehicle Parts & Accessories Experts
ZJ Limited
ZJ Limited
xxxxxx xxx
Thomas Perkins
Thomas Perkins
Are you a BMW Vehicle Part and Accessory Expert? Answer questions, earn points and help others
