SOURCE: audio driver for asus p5sd2-vm mbd os winxp sp3
find a way to remove servicepack 3 then try again.
if it works then re-upgrade to sp3
SOURCE: ASUS COMPUTER INTL P5SD2-VM MBD MATX LGA 775-SIS
You need to specify the exact problem.
If your PC doesn't boot up then it means that your system is not posting. This could mean that eaither your CPU or your motherboard is faulty. If you get a series of beeping sounds then you will need to replace the RAM. If your PC boots up but you get no signal to the monitor and if you were using a graphics card it now means that it may have become faulty and you will need to use onboard graphics. If you were using onboard graphics then your motherboard VGA has malfunctioned.
All in all I suggest you take it down to a PC technition to see which components are faulty.
Please use this link and it will redirect you to the webpage where you can download the right driver for your motherboard.
You need to save the file once you download the driver for you to have a copy for *********** board audio driver.
http://www.dl4all.com/sus/tag/asus+p5sd2+vm+audio+driver+for+windows+7.html
OR
http://ph.asus.com/Motherboards/Intel_Socket_775/P5SD2VM/
