SOURCE: How do i disable the touchpad of my Lenovo T410
Well if the bios is not password protected or u know the password there should be an option to disable in the bios.
SOURCE: where can I find lenovo T410 user guide so I can
You can download the manual for this unit from this links.
http://www-307.ibm.com/pc/support/site.wss/MIGR-74470.html
http://www.retrevo.com/support/Lenovo-T410-Laptops-manual/id/23611ci665/t/2/
SOURCE: hai,i had a bsnl3g mobile, when ever i attempted
CONFIGURE BLUETOOTH WITH COMPUTER
Hi friends
It s a simply way, to solve the problem.you will follow the instruction.
Follow the bellow step.
1. just enter your Bluetooth in your pc.
2. when the icon show your task menu bar just
3. double click on icon
4. add>check on my device >next(ensure phone Turn BT on )
http://www.acroname.com/garcia/tutorials/bluetooth/connection/connection.html
you can see the phone model which Bluetooth on.
just select the device >choice any ask code >I will advice you, please select, let me choice> type any 8 digit >next >now the same
number > in your mobile >finish
For dial up go r click on my network>properties>create a new connection> connect to internet>next >set up manually>connect
using dialup>select your mobile modem>next >type any name >type the exact name and number eg: for Airtel=*99#>next >no user
name and password just next >check on add short cut>and finish.
Just double click on the icon, it will connect soon.
Or
you can install PC suit and set it through the following step.
Setting> Setting >participate tic on yes .Double click on phone icon >next>tic on Bluetooth connection >next >select yes the phone
mobile>next
Remember always set the mobile for connection select the yes.
Hope it will help you.
SOURCE: factory reset for lenovo t410
if it is a newer model computer, 1 to 2.5 years old,there is an option in your Control panel setting to allow you to do that easily. or u tuibe may have a video of step by step to change the setting back
SOURCE: I can reset my password lenovo t410 pls try to help me
Try F8 or the F that you see in the screen at start up to to enter in BIOS setup.
