We moved our Phillips LCD 47 inch tv and now the picture has lines through it horizontally. The colors are shadowed with a green tint. Please help me fix this
Posted by mlissa1014 on
Sonny Berry
  • 8,617 Answers
I would try reseating the wire connections especially the LVDS cable from the main board to the Tcon Board.
Posted on Apr 06, 2013
5 Related Answers
Jozel
SOURCE: phillips model 50p8341 titanium-finished 50-inch Red tint to picture
how do u lower the g2?
Posted on Feb 09, 2008
Ecollier2012
Edward
  • 3459 Answers
SOURCE: picture shadowing and waving pictures
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Posted on Mar 21, 2009
MNfisherman
Nate Stansfield
  • 11896 Answers
SOURCE: green horizontal lines on screen no picture
The green CRT's (color picutre tube or color wheel, or ballast) will need to be tested for replacement.
It is quite common with these tv's
You will need an ohmmeter and or voltmeter and test each component for currency and accuracy
Posted on May 06, 2009
Slinteriors
Sonny Berry
  • 8617 Answers
SOURCE: Phillips HDTV Projection TV. Colors don't line up create shadow
yes sounds like a convergence issue. The following link has convergence repair kits which contain the parts and a cd with instructions on how to do the repair.
http://www.tvrepairkits.net/
Posted on Jul 10, 2009
roety
Eric Rotmil
  • 587 Answers
SOURCE: Sony 50' LCD Projection KDS50A2000 has a green tint on the screen
Yes sounds like a bad light engine (Optic Block), expensive part, but sony has extended some warranties on these for two or three years
link hope this helps
Eric
I’m happy to help further over the phone at https://www.6ya.com/expert/eric_ab7c09ec01841771
Posted on Aug 26, 2009
My 42 in phillips LCD flat seen has a black horizontal line toward the bottom how can I fix this.
Samsung LN46B650 Thin Black Horizontal Lines - Forums - CNET
www.cnet.com > Forums > Samsung
CNETI'm experiencing thin black lines from the top of the screen to the bottom. ... by babes808gpa / January 15, 2010 1:42 AM PST ... lines are about 1/4 inch apart from top to bottom of screen. starts on the right and about a 1/3 of the way toward the ...have the exact same problem, my lcd tv has multiple lines are horizontal it ...
Faulty HD- LCD - LED TV - Horizontal Lines STRIPS on the ...
? 3:05
https://www.youtube.com/watch?v=KiqJuMiEiak
Jun 8, 2013 - Uploaded by Sameh Moustafa
Faulty HD- LCD - LED TV - Horizontal Lines STRIPS on the picture SOLVED .... I just have one black line ...
TV Repair Help for Vertical & Horizontal Lines on Your TV ...
? 2:47
https://www.youtube.com/watch?v=b0sI7LB4cZE
Dec 20, 2015 | Televison & Video
Green Color Tint
I had a similar problem with my tv. Sometimes it depends where the tv is located, have you moved it? Magnesium in the earth caused my tv to have greanish tints in all four corners of my tv. Try moving your tv forward, backwards, or side to side. Let me know if this works.
Cynthia
Feb 01, 2008 | Panasonic PT-47WX49 47" Rear Projection...
Lcd monitor pink/green tint
Check the cable going into the back of your monitor and the cable from your monitor into your computer, one of them is most likely loose.
Dec 24, 2013 | HP Computers & Internet
Horizontal lines shadowed / blured picture after 20-30 minutes
There are some semiconductors or capacitors that are leaky. Might need thorough check up inside the TV.
Jul 07, 2012 | LG 55LH40 55 in. LCD HDTV
Green tint only on left hand side towards the middle of the screen
Tv have a problems known as a convergence problems,it dead.The tv have colors lines R,G,B mis alignments,have colors shadows pictures or 3D pictures look alike?The tv convergence board have dead 2 STK convergence ICS and some or all of it resistors too.These parts on the tv convergence board,must be replaced to solved the tv pictures convergence problems.The shop,will cost u like $300-350 for parts and labors.
Nov 29, 2010 | Panasonic PT-47WX53 47" Rear Projection...
Shadowing on lcd tv when tv camera moves left or right
it could have something to do with the refresh speed of the tv set not sure if you can change it have a look in the menu or manual hope this helps jim
Mar 16, 2009 | Philips 47PFL7403D 47 in. LCD TV
Green tint and psychedelic color swirls in picture
I have a good but with green tint on a polaroid tv model number 64SX505Y-DC02
Dec 28, 2008 | Polaroid FLM-3232 Television
FINE TUNING tv PICTURE
try calling the Insignia help line at 877-467-4289
Mar 28, 2008 | Insignia LCDTV26 26 in. Television
Televison & Video Logo
Top Televison & Video Experts
Marvin
Marvin
